Advice or process for hot sealing my block
Old Feb 6, 2015 | 06:48 AM
austinlandroverbill's Avatar
Default Advice or process for hot sealing my block
I just had new top hat sleeves pressed into my block to correct a slipped sleeve (cylinder 4), but before I start re-assembling the motor, I also wanted to "hot seal" it to assure that any remaining microcracks get filled.
Has anyone ever done this and can recommend a hot seal as well as a procedure to do it?
Thanks.
Old Feb 6, 2015 | 07:21 AM
dusty1's Avatar
I found several products at summit
In collaboration with Drow, came up with a simple hot water tank and old transfer pump.
Old Feb 6, 2015 | 08:11 AM
drowssap's Avatar
Thx u
Old Feb 6, 2015 | 08:14 AM
dusty1's Avatar
still couldn't figure out the best product choice...... in the end flipped a coin.
Old Feb 6, 2015 | 01:16 PM
ls1morethanyou's Avatar
add cement to the water jackets?
because racecar?
Affordable Small Block Race Engine - Super Chevy Magazine
Old Feb 6, 2015 | 01:29 PM
dusty1's Avatar
because racecar?
hard blok is the best for that.
we are referring to filling voids on the walls and help with heat dissipation and protection to combat future micro fissure bs
Old Feb 6, 2015 | 01:46 PM
you said LSx motor swap wrong hahahahaha
Old Feb 6, 2015 | 01:56 PM
cybercop's Avatar
Should you hot seal before or after pressing new sleeves in?
Old Feb 6, 2015 | 02:15 PM
dusty1's Avatar
Exactly why I have a disclaimer
Old Feb 6, 2015 | 02:17 PM
dusty1's Avatar
After with heads (all water jackets and ports) assembled. Is how I'm doing iy
