After Market Oil Pressure Gauge
Old Jul 6, 2011 | 09:32 AM
Default After Market Oil Pressure Gauge
Has anyone installed a oil gauge to their truck, did you use one of the adapter plates that install between the oil filter and the block to give you a port to hook to and if you did, where did you find that adapter?
Thanks
Old Jul 6, 2011 | 10:50 AM
dcarr1971's Avatar
Thanks
x2
This is pretty high on my 'to-do' list, but I haven't had either the opportunity or the parts to do it yet.
I know Glo-Shift sells the sandwich adapters, but none that they list as fitting our trucks. I did go as far as trying to find other vehicles that would share the same oil filter as I believe they would use the same adapter.
IIRC, some of the late 1990's era Ford Explorers also take a K&N HP-3001 size oil filter, so knowing that might make finding one of the sandwich adapters a little easier...
Old Jul 6, 2011 | 06:46 PM
bosshogt's Avatar
I used the the threaded plug nut on the side of the front cover. I have a 03 so I do not have a oil cooler, only a trans cooler. So I tapped that large 19mm plug to the same threading as the oil pressure sending unit. Its NTP pipe thread size. Screw it right in with a copper crush washer. No leaks and works great. Here is the writeup with pictures. My addition to the post start about the 3rd post down and 2nd page shows the install on the A pillar.
Installing an Oil Pressuge Gauge on a 2003 Disco II
Old Jul 6, 2011 | 08:06 PM
Street Wolf's Avatar
Anyone ever actually looked into "bumping up" the oil pressure on these trucks since it sucks so badly at idle? I know it's extremely easy to do on the Buick V6 block.
Old Jul 6, 2011 | 08:15 PM
This is right in the "write up" section.
https://landroverforums.com/forum/di...isco-ii-33978/
Old Jul 6, 2011 | 08:43 PM
DarylJ's Avatar
Why would you need to bump up the pressure, especially at idle?
You should be making 10 PSI per 1000 RPMs hot. If you are significantly less, your bearings or pump are shot and you can use thicker oil as a short term measure. If you are making significantly more, you need to figure out why, as you'll not be providing proper volume to cool and lubricate the motor. This is the biggest problem with "bumping up" oil pressures. You start getting too much pressure and your volume drops when it hits the OPRV too early in the RPM range.
Old Jul 7, 2011 | 11:07 AM
I want to thank those who replied, I did get a reply on the LRRF with what I was looking for along with a great selecton of gauges.
Old Jul 7, 2011 | 06:40 PM
Which set up are you going to go with Mike?
Have you found a good place for the gauge?
Old Jul 7, 2011 | 09:59 PM
priceg's Avatar
I retapped the oil sender port to 1/4 pipe then the adapted down to a 1/8 compression fitting.
Old Jul 8, 2011 | 10:06 AM
I am going with the sandwich adapter plate shown above along with 2 of their gauges, iol pressure and oil temp gauge. I will either use the grey "A" piller mount or a friend of mine found a dual mount assembly thru Rover that mounts in the coin tray on the dash that was sold over seas.
