Aftermarket gauges
So Im looking to install a series of gauges " oil pressure, water temp & transmission temp ) underneath my A/C controller ( in the area where the HI/LO shifter is ). My questions are: the gauges can be hooked up either electrically / sending units etc... or mechanically / old school tubing, fittings etc.. What gauges would benefit the better connection ( eletrically / mechanically ) and what area on the transmission would give me a good temp reading when I hook up the temp gauge.
what are you installing these for? what are you driving? i use a scanguage thru the ODB port and that has everything i could think of.... it doesnt ahve oil pressure but unless you have a 4.6 i wouldnt worry about that.
hilltop
I guess my main reason for installing them is to have a peace of mind. Im just a year old in owning a Land Rover and with all the horror stories of people smoking engines cause the low oil pressure light didnt come on till 4 or 6 psi and by that time they had enough time to kill the engine it was toast, I dont want to be that guy. The reason for the water temp gauge is that manual P.O.S that is in the dash does absolutely nothing from me. I want to know when my engine is running hot whether it be in Houston traffic or West Texas on a Mule deer hunt climbing from mountain. I want to be able to see if anything is happening. And finally, with these being AWD and cranking out 3000 RPM @ 75 MPH I would like to know my tranny isn't running hot. It all boils down to a piece of mind. I have build several hotrods in my 36yrs and never not having enough information is not a bad thing. I like to monitor everything I can, I may even through in a VOLTS gauge with the other 3. By the way I have a 2002 LR Disco II - 107K
Ditto on the ScanGaugeII. It is really cool. Well worth the $120 to $145 you can get them for on eBay. You can even mount it right behind your steering wheel on the black shroud with Velco. Set it to dark green back-light so it matches with your instrument cluster at night. I normally keep my 4 guages set to RPM, Voltage, Water temp, and Air intake temp. But there are many more you can choose from RPM, MPH, MAP, IAC and instant MPGs which is a little depressing There are many more I would have to look up.
Also its great to read all your SES codes too. Like the 0455 gross evap leak that comes on about once a month. I just reset and and keep rolling
I have a 2003 with the oil VIN Death Range. I'm sitting here looking over the install for my digital green oil presure guage. I thought fuel pressure might me another good presure to monitor and it may be an easy install with the fuel railing having the scrader valve on the end. Although I may have to take the top manifold off to get to that.
Now I am figuring out were to put 1 or 2 2 1\16" gauges so they look nice and custom. The A pillar is an idea, but also to the left of the instrument cluster may work too. for a vertical stack.
Here is my digital oil presure gauge on eBay
Cyberdyne A010E160Y Oil Pressure Gauge Emerald Green
I have the ScanGuageII installed currently. Its great!
Also I have a oil presure gauge that is electronic(digtial). It has a electronic sending unit. Only one electric wire connects it to the front cover since it uses the theaded part as a ground(negative). I will start installing it Monday. It seems simple but I need to find out the best location on my dash, and also to find the dimming wire for the interior instrument cluster lights, the positive power wire for on/off when the engine is turned off.
Here is a great step-by-step write up for the oil pressure gauge.
http://www.landroverclubvi.com/oil-gauge.html
hilltop
I have a Faultmate from blackbox-solutions.com for my Disco. I'm a long way from a dealer, and I prefer to do my own work, so it has worked out well for me.
Wonder if it would be possible to get the same info from it into a convenient in-dash display?
-Aaron
-Aaron
I'm with the OP and prefer to actually have gauges to let me know what's going on. A digital readout like the Scangauge is ok but I find it distracting when I'm driving. I prefer to just see a needle pointing rather than having to read a number. It's been proven that drivers/pilots learn where the needle on a gauge should point during normal operation and can tell if the needle moves from that point without having to focus on the gauge.
