Aftermarket temp gauge
Old May 21, 2019 | 04:39 PM
T5174's Avatar
Default Aftermarket temp gauge
I did a head gasket job on my 02 disco back in December, she has 165,000+ on so I figure it was time. That job went well, and from reading on here about the dummy light I decided to add an aftermarket temp gauge made by Bosch. It seemed to be pretty straightforward coming out of the package. It has 3 posts on the backside, one for 12v,one for ground and one for the temp sensor (sending unit). I thought I could get away with tapping into the existing sending unit wires, and the gauge worked except it triggered a trouble code and the red dummy light lit up and the needle never rose above cold. So I undid the wiring to the new gauge and everything went back to normal. Here's where my headache begins, I bought from glow shift a tee adapter (the gs-aw32) and decided to add a sending unit in my top hose. The only problem is now the Bosch gauge isn't working, the gauge itself is grounded to the engine ground on the firewall, I have the 12v power hooked up, and the sending unit is hooked up but to no avail. I called Bosch and spoke to tech support and they suggested that I ground the tee from glow shift so I did, still to no avail.
Can anyone here help me figure this out?
Old May 21, 2019 | 04:47 PM
mln01's Avatar
Send back what you bought and buy an UltraGauge. Why make this more difficult than it needs to be?
Old May 21, 2019 | 05:31 PM
Extinct's Avatar
I recommend the Autool because it is easier to mount, and matches the dash light color. Also like the ultragauge it has a settable alarm. That said, how many wires does your new sending unit have? What is the PN of the gauge you bought?
Old May 21, 2019 | 05:49 PM
T5174's Avatar
It has 1 wire on the sending unit and the gauge is already mounted and I'm not concerned with color matching. The part # is FST-8211
Old May 22, 2019 | 03:43 AM
Extinct's Avatar
My guess is you don't have the sending unit adequately grounded, post a pic of your install.
Old May 23, 2019 | 08:38 AM
T5174's Avatar
So after driving around a while the other day my aftermarket gauge started working, I suppose I wasn't giving it enough time to get a reading. Although it takes about 15 minutes to start climbing, is that normal for it to take so long to start showing a reading?
Old May 23, 2019 | 08:45 AM
fishEH's Avatar
It depends what the low end of your gauge starts at.
Old May 23, 2019 | 09:15 AM
T5174's Avatar
The lowest is 100° and the highest is 280°.
I also have the sending unit in the hose that is held down by the top half of the fan shroud, and I understand that being in that location I won't get a 100% accurate reading. I had my code reader hooked up and there was about a 15° difference
originalpy
May 4, 2021 09:16 AM
lighting
Mar 27, 2015 05:54 PM
2Discos
Sep 9, 2013 04:23 PM
MC04DII
Feb 15, 2013 12:13 PM
Fitzy250
Oct 15, 2011 06:41 AM
