Air Con Drain
Crawl under the passenger side behind the front tire. Find the DC joint on the front prop shaft and look just above that on the body. Its a little rubber grommet inserted in the sheet metal. Sort of a nipple with a flat slit.
It's correct that the A/C drains look like rubber grommets, perhaps 1.25" in diameter on the inside of the trans/driveshaft tunnel on either side.
Use a long screwdriver or a length of coat hanger wire to poke in the middle of the fitting, but be careful to not be lying directly under it when you do so because you might otherwise get a faceful of not-so-nice water!
skewett
Jun 3, 2007 08:15 AM
