Air intake drain
Old Dec 9, 2018 | 03:25 PM
Ben Matheson's Avatar
Default Air intake drain
My air intake moulding doesn't sit flush so I'm taking on some water. I will be replacing it but I'm sure even with a new one some water will find it's way in. I assume there must be a drain in that area? How do I find and clear it?
Old Dec 9, 2018 | 03:30 PM
The Deputy's Avatar
There is a small drain hole in the air cleaner housing.
​​​​​​​ Brian.
Old Dec 9, 2018 | 03:36 PM
Just to be clear I am talking about the the HVAC intake at the bottom of the windshield not the airbox for the engine
Old Dec 9, 2018 | 04:14 PM
Richard Gallant's Avatar
Welcome to my nightmare I have been fighting an intermittent passenger side leak for year - it is zero fun to deal with
Old Dec 12, 2018 | 08:14 PM
Llamasayswhat's Avatar
The cowl vent intake is known to leak if the seal on it wears out and crumbles with age. You will have to remove the A-pillar trims and the wiper cowl to access it. Remove the HVAC intake and clean and seal it up against the body again and you should be good to go.
Old Dec 12, 2018 | 08:29 PM
Thanks for the reply new cowl ordered imI just shocked one flimsy piece of plastic with a rubber strip is all that's keeping water out
Old Dec 13, 2018 | 10:24 AM
Actually it is simply a design flaw, with age everything loosens up and the air intake is poorly protected from water entrance. I ran a bead if silicone along the top of the rubber seal, corrected the cracks, and cleared the drains everything is fine until we get heavy rain then water gets in.
Old Dec 13, 2018 | 10:35 AM
zuke's Avatar
I got those Malaysian fiberglass A-Pillar trim pieces and was happy with them. The same guy makes a fiberglass cowl that I thought I would try out. 1/2 the cost of plastic. Also it has the tape to seal against the windshield which I think would solve alot of problems.
Old Dec 13, 2018 | 11:06 AM
JUKE179r's Avatar
That's my next step is to buy that exact cowl.
Old Dec 13, 2018 | 11:52 AM
Where are you seeing them for half the price of OEM I see it on eBay but by the time you add shipping from Malaysia it's about the same price
