Air shocks
Old May 8, 2008 | 07:51 AM
mummra's Avatar
Default Air shocks
Hey guys: I went ouit in the mourning about a month ago to find my rear left air-shock was empty /rear right riding low.I turned on the vehicle . and it raised and remained rasied and problem free for one month..Then latelast night ii went out . to find both rear air shocks deflated. I turned on the vehicle as before but this time . No raising . I then drove around my circle and both raised and remained raised and are raised and level now.. Is this a fuse or computer problem . or is it a valve or other? The bagz themselves are obviously fine for they stay infalted when the engine is off. (accept for these 2 occasions)
Old May 8, 2008 | 12:58 PM
Default RE: Air shocks
First of all, they are air springs/bags, not air shocks. How many miles on the truck?
Do you have a good mechanic, is so, it is time to go see him.
Old May 8, 2008 | 11:33 PM
mummra's Avatar
I do have a mechanic . he owns a rover himself.. So i will def . go see him then .. what would you think my problem is? Evn now as I write this 12 hours after my first post .. they are still level and inflated and i drove it all day until 6pm.
Thanks mike
Old May 9, 2008 | 05:26 AM
Urban Panzer's Avatar
Hi, this "can" be caused by "spurious" messages from the level sensors as they wear out and give wrong messages to the Air system. If you check the airbags for leaks and find none (ie inflate and use a soapy solution ALL over them) then keep an eye on it as it may not happen again or to often..
dougwrench55
Nov 19, 2013 12:51 PM
kenny453
Jun 21, 2013 06:58 AM
cavdiver2
May 13, 2013 02:40 AM
arnottdoug
Apr 26, 2012 01:39 PM
