Air Suspension Conversion Complete- Now what?
Old Jan 28, 2009 | 06:07 PM
enrique's Avatar
Default Air Suspension Conversion Complete- Now what?
So I recently converted from Air Springs to Coil springs and I've been snooping around and discovered that the computer needs to reset or updated. Anybody have any detailed info on this.
Thanks
2004 Discovery HSE
Old Jan 28, 2009 | 06:35 PM
Disco2Guy's Avatar
Default RE: Air Suspension Conversion Complete- Now what?
You need to take it to a dealer (or indy shop with capable software) and have them turn off the SLS option. If you don't, it shouldn't have any impact on driving aside from a fault light on the dash.
Old Jan 28, 2009 | 07:21 PM
I believe that AB sells a kit to do this.
Old Jan 28, 2009 | 08:30 PM
Britabroad1's Avatar
5th Gear
Spike - I think the Ab kit is just for the Range Rover. The Disco 2 SLABS (Self Leveling & ABS) ECU needs to be reprogramed to think it had coil springs from the get go. Or you could be a lazy bugger like me and not bother. - Light comes on once every 2 weeks and resets when I switch off. Stealer wants $170 to re-program.
Old Jan 28, 2009 | 09:18 PM
unimoged's Avatar
I did the conversion on my 2001 SE7 and used an AutoLogic diagnostics system to go into the options menu and remove SLS. A friend at a local shop let me use the system one weekend. Can't stand lights on the dash.
http://www.autologic-diagnos.co.uk/
SkymonkeyONE
May 8, 2013 12:29 PM
Paul Grant
Nov 30, 2012 12:48 PM
Lincoln Tarantino
Apr 4, 2012 01:20 PM
Paul Grant
Dec 11, 2011 05:50 PM
bennycisco
Jan 20, 2007 11:52 PM
