air suspension help
Old Feb 9, 2010 | 01:52 PM
jrm123180's Avatar
Default air suspension help
I need help with my air suspension.
I have a 2003 Land Rover Discovery HSE. The leveling system doesn't seem to be functioning properly. the rear passengers side leans to the right and sometimes the rear will just drop all the way down. I have the down hill assist warning light on, the TC light and the ABS lights.
Any suggestions as to where to start with this problem? Also, how to I figure out if I have a remote leveling system installed? This car was purchsed used by my GF a few years back.....
Thanks,
Steve
Old Feb 9, 2010 | 02:01 PM
okdiscoguy's Avatar
Does it lean after sitting? Spray the air bag to check for leaks
Old Feb 9, 2010 | 02:06 PM
salve7's Avatar
The three lights are related to brakes so they won't apply to ur problem. Get a bottle of soapy water and spray the bag down really well. I raised my suspension before I sprayed to make it easier. If you don't see any bubbles, work your way along the air lines until you get to the compressor box. Since it is just one bag you prob have a leak and you can get replacements from arnott industries that have a lifetime warranty. If it has the air suspension then you have the "remote leveling system" but you will need to buy a remote to use it and all it will do is drop your suspension down so it is easier to attach a trailer.
The three amigos/ lights are a separate matter that I haven't dealt with yet so I can't help you there. Do a search for the three amigos and you will find a ton of info. Hope this helps!
Jay
Old Feb 10, 2010 | 07:10 AM
docharo78602's Avatar
If it is the air bags Strutmasters has a good replacement I have had mine for 4 months now and no problems. Easy to install and a direct fit i got doth of mine bought and shipped for 376.00
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
