air suspension help
Old Jun 22, 2007 | 09:15 AM
keithark's Avatar
5th Gear
Default air suspension help
the model is td5 year 2000
[hr]
, i have one other question, when the back goes down it is equal both sides now im thinking maybe its not the air bags .unless they have both starting leaking at the same time! is ther some sort of valve maybe that could be letting the air out, any input would be helpful[/align][/align]
Old Jun 22, 2007 | 09:42 AM
Default RE: air suspension help
You are probably going to need to go have some scan your ECU for a problem with the SLS. Either the pump assembly is failing allowing both sides to drop or the ECU is causing it to happen.
Mike
Old Jun 22, 2007 | 10:05 AM
keithark's Avatar
5th Gear
sorry, what is the sls? and is it only main dealers that can read the ecu
so are you saying the air could be escaping thrugh the pump? also i forgot to say i only loose the air if its parked unevenly or up hill other than that it is ok most of the time ,thanks for your reply
Old Jun 22, 2007 | 10:24 AM
SLS, self leveling system, dealer or any shop that has a note book, auto logic or some compariable scanner can cgeck for problem and reset or calibrate the system.
Mike
Old Jun 22, 2007 | 10:59 AM
keithark's Avatar
5th Gear
mike , thanks for the replies , youhave been very helpful, any ideas why the back only goes down on certain surfaces though?
Old Jun 22, 2007 | 11:15 AM
Could be related to the hright sensors which are located on the rear trailin arms. System may just need to be recalibrated.
Mike
Old Jun 22, 2007 | 11:56 AM
keithark's Avatar
5th Gear
thanks for all your help mike ,will let you know how i get on,
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
