Aircon dead suddenly
Old Aug 12, 2008 | 09:30 PM
yuenie's Avatar
Default Aircon dead suddenly
Aircon goes dead in the hot summer. ...
Freon checked : level sufficient
Compressor checked : working
What the heck the problem can be???
Old Aug 12, 2008 | 09:39 PM
AK Rover's Avatar
Default RE: Aircon dead suddenly
Off the top of my head I'd say check to make sure all the fuses and relays are good. You could have a switch that went bad from use. Fuses are by far the easiest to verify if there is a problem. Relays you just have replace and see if anything changes . How did you verify the compressor was working properly?
Old Aug 12, 2008 | 09:40 PM
DI or DII?
Old Aug 12, 2008 | 09:50 PM
roverguy7's Avatar
how did you check the comp, and the freon charge?? is it not cold, or does it not blow?
Old Aug 12, 2008 | 09:51 PM
Do your electric fans come on? How about the HVAC blower, does it work? Your A/C might be working fine but your blower may not be working.
Old Aug 12, 2008 | 11:39 PM
yuenie's Avatar
thanks guys.
air is blowing strongly....but it's warm.
My LR is 2001 D2.
Old Aug 13, 2008 | 09:48 AM
Darover's Avatar
Then your freon has to be changed I'd say. Unless you have the same thing I had a couple of months ago. I had checked the connection under the hood for the compressor, and although it was snapped in place, I hadn't noticed that one of the wires in that connection had pulled out inside a connectorjust enough to not make contact. So just push all the wires in as deep as they will go and see if it changed anything.
Old Aug 13, 2008 | 11:50 AM
yuenie's Avatar
ORIGINAL: Darover
Does that mean your compressor is not working? The thing is my compressor seems to be working as I can hear the sneezing sound inside the car.
Old Aug 13, 2008 | 03:15 PM
Darover's Avatar
You got me there,NO, my compressor was not coming on. But are you sure yours is. Open the hood and check.
Old Aug 13, 2008 | 03:39 PM
yuenie's Avatar
yes, my compressor is working fine. That's why I am having a headache. It can be a big job to find out which duct is blocking. Perhaps a dismantling of dashboard...?!
