Alarm problems with Disco II
Old Sep 20, 2012 | 04:49 PM
doorfixer's Avatar
4wd High
I will try that first. Thanks for your help. I will post my progress. I just picked up a new battery and put it on a charger for the vehicle. I will install it this evening.
Old Sep 21, 2012 | 07:41 AM
doorfixer's Avatar
4wd High
Tried eka with no luck. Tried a few different times waiting half hour in between. New battery with full charge in the vehicle. I may try bcu/ecm swap. Does the fact that they come from another unit that was working help me. Should they be synched together already??? I'm also going to see if there is a local shop that has computer to reprogram if necessary. Still open to suggestions.
Old Sep 21, 2012 | 08:52 AM
jafir's Avatar
Yeah. If they came from a running truck, you should be good to go.
Perhaps the drivers door lock actuator is bad. When you unlock the drivers door, do all the other doors unlock? You might have to unlock twice in a row, depending on how the BCU was programmed.
Old Sep 24, 2012 | 09:19 PM
doorfixer's Avatar
4wd High
I still have not switched bcu/ecm but noticed that all doors unlock except door behind drivers door. It also does not lock/unlock from locking switch on dash. Can this cause alarm trouble. I still want to switch computers from other disco. Should have time in next few days.
zoomlenz4u
Dec 30, 2008 01:45 PM
daveohare
May 4, 2008 10:54 AM
howardstapley
Jul 23, 2007 11:56 AM
bigugly82
Feb 22, 2007 04:23 PM
phuzzzed
Feb 6, 2007 11:37 PM
