Alignment Help?
Old 12-03-2007 | 10:45 AM
Default RE: Alignment Help?
Try rotating your tires, also, check your air pressure.
Old 12-03-2007 | 01:22 PM
98roverguy's Avatar
They should have checked the tire pressure before they did the alignment. If your drifting left, increase the pressure on the left tire by about 5 psi higher (or lower the right 5 psi) hen the right. It may help level it off. But I don't know how off it is.
Old 12-03-2007 | 05:18 PM
okdiscoguy's Avatar
4 new tires and alignment. Same problems...
Does it drift to the left, or is your steering wheel just not cantered going down the road? It can be within specs and still not centered. It took me 4 trips down the road to get mine centered after an alignment.
coors
05-11-2013 09:48 AM
sdrovn
12-21-2007 10:38 AM
Waggy23
05-16-2007 10:00 PM
Bubba_13
09-07-2006 11:05 AM
jomeheretu11
10-31-2005 06:55 AM
Quick Reply: Alignment Help?
