all my lights went out, ONLY headlights work?
So out of no where, the taillights don't work, side lights and the fog lights dont work. Only the headlights work. HELP!! What could it be, it just happened, out of no where?
i am looking at the schematic on my rave file
maybe someone else knows how to copy the page and post it. but if you start under the hood and check there then the passenger compartment. i believe all the fuses, relays and flashers will be there. might even be labeled.
the diagram shows the fuse panel from the engine compartment running through the one in the passenger compartment. via the switch in the dash etc,,,,
i image a fuse or number of fuses or relay had to pop
ORIGINAL: sloppyjoe
Open the page, hit Alt+Printscreen
Open Paint Go to Edit in toolbar click Paste
Screenshot Image will appear
Save Image
Upload to www.photobucket.com or other Image hosting websight
Click image in text tools, insert link to image there.. VWALLA
wow, sounds like good info but would be nice with some pics of the diagram or pics of the location. The fuse panel im talking about is the passenger one right behind the battery:
somehow he's lost 15 power check the main fuse panel. If i remember correctly the load reduction relay will also knock out the headlamps. scott if you need a walkthru pm me and we will powwow
while i am at work so ill have real data.
