Alternative to $159 Fog lamp replacement?
I noticed my driver side fog lamp went out the other day, and figured i'd replace both while i'm at it, but when i looked u the fog light replacement assembly, for just one, it costs 159 dollars. So i'd be looking at 318 dollars for fog lights!? If i had known how expensive they were before, i probably wouldnt have had them on all the time. Anyone know other options, hopefully, cheaper ones?
98 disco
98 disco
on
REMOVE THEM COMPLETELY.
Are you talking about the assembly that is partt of the plastic air dam?
One of mine fried real bad before I bought my Disco. The previous owner had experienced multiple electrical problems due to it shorting out, possibly from him driving thru mud puddles.
I recently removed the entire air dam and the fog lamps as well. i like it much better with the additional front ground clearance.
I did mine several years ago, then mounted (2) 4" 110w eagle eyes on top of bumper.
wired into existing running light wires, (now unused), works great.
In some states, it's illegal to drive with off-road lites on, so check.
luck,greg
bufaton
03-24-2013 02:22 PM
