Alternative to CDL linkage arm/control?
Old Sep 20, 2012 | 03:13 PM
nychaze's Avatar
Originally Posted by Spencerfitch
So according to that, I don't have to worry about the 03 disengauged restart deal.
finally one upside
Article is correct...i have an 03 with the D1 lever and no issues...plus you dont have to remove any solenoid on the 03/04 that could leave you stranded on the trail stuck in low range....the only benefits to the 03/04...well that and the headlights look awesome...
Old Sep 20, 2012 | 03:42 PM
ZGPhoto's Avatar
Did you put a D1 t-case in? I'm not understanding how you would lock the CDL without the hardware being present on the top of the t-case box.
Old Sep 20, 2012 | 04:16 PM
nychaze's Avatar
Swapped out the front nose assembly.
Spencerfitch - What did you do? The whole case or nose?
Old Sep 20, 2012 | 04:20 PM
ZGPhoto's Avatar
What has to be removed to do that? Front driveshaft and x-member or more?
Old Sep 20, 2012 | 04:38 PM
nychaze's Avatar
2003CDLInstall - LAND ROVER CLUB V.I.
Amazing write-up....really not a bad job.
Both x-members, y pipe, muffler, front shaft, trans mount (i think), and a bunch of bolts. Basically free the transfer case it up so you can angle the front down and slide the front house off and slide the new one on.
Did mine over the course of a weekend.
Old Sep 20, 2012 | 07:38 PM
ZGPhoto's Avatar
Thanks, I think I'll have to cut off my front X-member unfortunately, she's pretty seized on there. Looks like it's not too hard to do, and that's a cheap kit from toddco!
Old Sep 20, 2012 | 08:08 PM
jafir's Avatar
That toddco kit is what? $400? There is a guy on discoweb selling the entire case for $200.
Old Sep 20, 2012 | 08:35 PM
909wheeler's Avatar
If you buy the CDL linkage for $475
Old Sep 20, 2012 | 08:38 PM
nychaze's Avatar
I fell for the toddco trick....shame on me
Its not a "kit" all the damn thing is the front output housing off any respectible disco that had a locking CDL.
Call Paul Grant (dMike signature has contact info) or any other LR used parts guy and they can get you what you need a hell of a lot cheaper than toddco...and you dont need to buy a whole case just the front output hosing (weights 10-20 lbs) cheap shipping...even if you can get an entire case at $200 shipping will reem you good....
8 of the 16 cross member bolts snap when i did mine...start soaking them now and run an impact on them when you do take it off....the heads will snap off before anything else and make sure you use a 6 sided impact socket.
Old Sep 20, 2012 | 08:47 PM
jafir's Avatar
He's got another post where that is just his price. I didnt even get offered a discount with the $475 shifter. needless to say I didn't buy just yet.
$200 Is including shipping, I think.
