Alternative to CDL linkage arm/control?
Old Sep 20, 2012 | 10:07 PM
  #21
ZGPhoto's Avatar
Originally Posted by nychaze
I fell for the toddco trick....shame on me
Its not a "kit" all the damn thing is the front output housing off any respectible disco that had a locking CDL.
Call Paul Grant (dMike signature has contact info) or any other LR used parts guy and they can get you what you need a hell of a lot cheaper than toddco...and you dont need to buy a whole case just the front output hosing (weights 10-20 lbs) cheap shipping...even if you can get an entire case at $200 shipping will reem you good....
8 of the 16 cross member bolts snap when i did mine...start soaking them now and run an impact on them when you do take it off....the heads will snap off before anything else and make sure you use a 6 sided impact socket.
I think the head will strip off before anything else happens on my truck. It's an Arizona truck, not a spot of rust(incredibly rare on any DII you see in New England, or a lot of other places too). We soaked the bolts in PB blaster a couple weeks ago and attempted to use an impact to remove, stripped the heads(not sure how it happened, it was my mechanic doing it). I may have to just cut the piece off.
Also, I didn't realize it wasn't a complete kit, that's pretty BS false advertising. I think I'll continue to look for a complete 04 DII t-case with linkages, then I'll have mine as a back up if it fails.
Old Jan 13, 2013 | 04:30 PM
  #22
NickAdams's Avatar
Default Where to get a lever?
I'm ready to install my own version of the push/pull cable. I'm having trouble coming up with a lever to bolt to the cdl nipple. Suggestions?
Old Oct 23, 2013 | 09:16 PM
  #23
acg's Avatar
acg
Has anyone purchased rom this seller in Poland? Looks like a good deal for a new assembly for $349:
CDL Land Rover Discovery 2 D2 Central Difflock Diff Lock Shifter | eBay
Old Oct 24, 2013 | 07:45 AM
  #24
drowssap's Avatar
yes I bought it a couple of years ago when he first started selling them, I think I paid $249.00 works great. I did have to enlarge one hole but it works great and it doent have the factory solenoid on it.
turbodave
Mar 29, 2019 07:22 AM
94svt50
Jan 4, 2015 03:21 PM
moorebl
Oct 3, 2014 09:59 AM
Disco Mike
May 4, 2011 07:08 PM
Disco2Guy
Nov 27, 2007 04:54 PM
