Alternatives to Terrafirma steel wheels? Vibration problems?
Old Aug 6, 2021 | 04:54 PM
Dsport's Avatar
Default Alternatives to Terrafirma steel wheels? Vibration problems?
I’ve had my modular TF wheels for just about 2 years. And always had vibration issues. I literally watch my dash and passenger seat shaking. My old truck had the OEM steel wheels (NATO I think?) and was surprising smooth.
Are there any readily available steel wheel options other than the Terrafirmas?
Thanks!
Old Aug 6, 2021 | 06:13 PM
Xanthro's Avatar
Thanks!
Check they are balanced correctly and the tires are properly faced. Some off road tires have a side that faces out.
I have the Terrafirma steels with 265/75r16 and there is little vibration. Plus, mine are aggressive treads.
Old Aug 6, 2021 | 06:33 PM
Dsport's Avatar
thanks, this is all correct. I’ve had them balanced 2 times after the initial mount and balance. This is partially due to aggressive off-roading and tires chunking slightly. There is the second set of tires I’ve had in these wheels. The first had vibration issues too. 3 different shops have balanced them. They are MT’s so they are aggressive, but that shouldn’t matter too much.
One of the wheels was visibly wobbly out of the box (tire guy pointed this out) I use this as the spare.
Nice to know you have had OK luck. However, I didn’t think mine were too bad either until trying some other wheels.
Old Aug 7, 2021 | 12:03 AM
SouthxSW's Avatar
There’s a brand called Tuff Torque 16x8-35
check out bluediscoverygirl on insta for pics
I‘ve seen some people running 17’s as well, might check with a tire shop.
Old Aug 7, 2021 | 01:34 PM
Xanthro's Avatar
Do you have a lift, otd if so how much? The size of your tires and lift may be throwing off alignment and you'd benefit from caster corrected Radius Arms to bring it back into the proper angle.
With aggressive tread there will be some vibration, but yours sounds significant.
Old Aug 7, 2021 | 04:03 PM
donniefitz2's Avatar
I just spent several days trying to find steel wheels for a D2. It's pretty much impossible. The TerraFirmas are the only game in town anymore. There is the modified Honda Odyssey option, but it takes some machining.
Old Aug 7, 2021 | 04:46 PM
Black Dynamite's Avatar
I think you just answered the question I was about to post. I’m looking for 18” steel wheels. A Soft 8/Baja 8 style.
Old Aug 7, 2021 | 06:13 PM
dswilly's Avatar
This guy on instagram used a VW wheel. It is for a model not sold in the USA but there is a US equivalent. Like the Touareg or something. If I remember I could not find the wheels in steel. He had to machine the center bore too. He is in Panama and they do some pretty cool off roading down there. Very muddy.
Old Aug 7, 2021 | 07:47 PM
Dsport's Avatar
Couple things I’d like to mention since it looks like some are interested.
1) There is a steel wheel that works without machining (maybe odyssey or VW I forget). Here it is on the back of my old D2. (It used to have twice as many holes but I welded up every other hole to match my OEM rover steel wheels). This wheel only worked as a spare because the area around the lug nut would distort when it was torqued. Second photo shows the alloy 16, Odyssey 16, OEM rover 16 (order from left to right) with the terrafirmas boxed up in the background.
2) the soft 8 wheels (forget the brand) are no longer offered in a positive offset (I called the manufacturer and confirmed they are discontinued with no plans to remake) highest is +0 offset only which looks dumb on our trucks IMO. +25 seems perfect on our trucks (tiny bit of poke) and is as aggressive as I’d like to go.
3) FYI the Odyssey/ VW wheels can be ran without machining because the offset is so high (+50 ish, just run a wheel spacer) only problem is this puts us back at square 1 since it would need to be a non-hub centric spacer which may cause vibration. But I’d love to try this method and run 17s since I can source a 34” tire (16s are 33” or 35” nothing in between, and I’m running 4.12 gearing so it won’t be too bad)
4) I’m going to try centering rings on my wheels. It’s worth a shot. I found a couple size options. And will post specs if anyone’s interested.
Old Aug 8, 2021 | 08:47 AM
dswilly's Avatar
Your Odyssey wheel looks different than the ones I used for my set up. The machining done is for the center bore and not for off-set 64.1 to 70.1. Not sure how you would machine a steel wheel for offset adjustment. The Honda Odyssey has nearly the same offset as a D2 at ET 50 vs ET 57. This moves the wheel outboard 7mm. This was important to me as I did not want the wheel to mess with the factory geometry or need wheel spacers, or look weird.
