Alternator
Old Jul 11, 2008 | 07:01 PM
baddiscoII's Avatar
Default Alternator
I have a 99 discoII with 105000 on it. I had alternator put on it last year. Got in it today really hard to start. Checked the battery 12.4 volts. Terminals little corrodid. Cleaned them started and checked the running volts 13.3 volts. Truck starts, but is that a low volt output. Should it be closer to 15v? Any advice on exhaust manifold gasket replacement?
Old Jul 11, 2008 | 07:53 PM
Default RE: Alternator
How old is your battery?
Old Jul 11, 2008 | 08:58 PM
okdiscoguy's Avatar
Douse the bolts for your manifold gasket in pb blaster a couple of times before you try to break them loose. If you have an EX leak, look at your manifold and the welds around the down pipe. Common place to leak.
Not sure on your voltage, just clean everything and see how it goes. You Batt might be gone and drawind the V down.....
Old Jul 11, 2008 | 11:14 PM
rrhyne's Avatar
My ScanGauge reports 13.4-13.7 under load while running. No problem starting.
Old Jul 12, 2008 | 08:22 AM
jkid's Avatar
15 volts would be bad for your battery. I'd get a new battery before winter comes, yours is almost 50% dead right now and sulfation starts at about 12.4, which really reduces your amp output. What do you mean by "hard to start"?
Old Jul 12, 2008 | 12:02 PM
baddiscoII's Avatar
Battery is about 3 years old, trucks sound like it take a little more for the starter to turn over. Starter sound slower.
Old Jul 12, 2008 | 12:10 PM
Sounds like your battery is going south. If you take the trk to AutoZone they will test your battery and alternator for you.
Old Jul 12, 2008 | 02:00 PM
Rovers ideal range is 13.6 to 14.4 to keep the ECU's happy.
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
arocena409
Sep 24, 2005 06:26 PM
ibncalb
Jun 2, 2005 09:02 AM
mke137
May 9, 2005 04:52 PM
