Alternator/Battery/cable
Old Aug 15, 2019 | 10:28 PM
Martin Apablaza's Avatar
Would you happen to have a picture or this cable. Having some similar problems over
Originally Posted by starcraft1
I just wanted to post the solution. I was going replace the alternator because I saw that the battery had held around 12.6v after a trickle charge (it had sat around 8 hours in the cold so I figured it wasnt at fault). Anyway after trying to get the alt out for about an hour, I finally managed to get it up and over the upper t hose of the radiator. After I did so I noticed that the little wire (Im imagining ground) had be severed down where it meets the larger plastic sheathing. I cut and spliced the wire back together and wallah, charging battery. Hope this helps someone in the future
Old Aug 15, 2019 | 11:29 PM
Richard Gallant's Avatar
If you look at the back of the alternator you can see the 3 wires, you can follow them to their termination fairly easily.
Nov15
Jan 10, 2024 05:01 PM
J P Cook
Jun 4, 2014 09:40 AM
kamileon
Mar 30, 2011 12:55 PM
99landroverdisco
Jun 2, 2009 04:53 PM
tailchaser0527
May 14, 2008 07:05 AM
