Alternator Post Loose
Old Apr 19, 2011 | 08:18 PM
humroot's Avatar
Default Alternator Post Loose
Hey folks,
So i had a dead battery again this morning. I traced the issue to a parasitic draw from the alternator. Looks like the negative post on the back of the alternator is loose. When I wiggle it I can see the multimeter move from 2-3 amps to 0. So my questions is this: Can this be fixed or do I need to replace the alternator?
As always, thanks!!
Old Apr 19, 2011 | 08:29 PM
Take the alt apart and tighten the post, there should be a screw/nut on it to hold the post in place.
If not you can solder or JB Weld it.
Worse case scenario you need a new alt.
Old Apr 20, 2011 | 11:27 AM
humroot's Avatar
Thanks, Spike.
Got the alternator out and the cover off. The plastic that holds the post in is cracked. I can get the post seated where it is supposed to go and it makes contact fine where it's supposed to. I think a little gorilla glue should hold it in fine.
Thanks!
Old Apr 20, 2011 | 11:31 AM
Bundu's Avatar
Banned
It's not a true Southern truck unless it has some gorilla glue on it.
Old Apr 20, 2011 | 12:31 PM
DarylJ's Avatar
Also acceptable: J.B. Weld
Old Apr 20, 2011 | 02:47 PM
humroot's Avatar
Gorilla glue did the trick! All back together and working as expected.
Old Apr 20, 2011 | 09:32 PM
Sweet.
LOVE Gorilla Glue.
JumPeR04
Dec 17, 2009 07:57 PM
robot808
Nov 18, 2009 11:10 PM
mgabriel
Dec 11, 2008 11:53 PM
