Alternator Short?
Old 04-30-2007 | 04:07 PM
Lnghrn Disco's Avatar
Default Alternator Short?
I read a post from January related to a guy with a battery that wouldn't keep charge. Disco Mike suggested that it might be a short in the alternator. Is this relatively common? I've done a little investigation of my own 95 Disco, and I think I have an alternator short. The battery drains down over the course of a day or so.
I tried to hook up an ampmeter in line with my battery and at the fuses, but my ampmeter fuse was fried (before I tried this), so I was out of luck. However, I could hear a distinct buzzing that sounded like it was coming from the alternator when the battery was connected. This buzzing went away immediately when I pulled the alternator fuse. It really seems like an alternator short, but I would appreciate some confirmation before I have my alternator rebuilt or buy a rebuilt alternator ($150-170 on eBay with shipping).
Thanks.
Old 04-30-2007 | 07:13 PM
Aquaholic's Avatar
Default RE: Alternator Short?
Wal Mart or most part stores should be able to test it for you.
Old 05-03-2007 | 07:53 PM
Well, after hearing numerous horror stories about failing remanufactured Rover alternators, I decided to get a new alternator. RoverConnection.com has a new alternator for my D1 for $260 plus $15 shipping. Pretty impressive considering that most local shops were selling reman's for the same or more. It's supposed to arrive on Monday. I'll post my opinion of the aftermarket alternator after I finish the replacement.
Thanks for your help and the local contacts, Mike.
~donald
Old 05-03-2007 | 11:20 PM
Good luck and make sure all your connections are clean when you hook up the new alternator.
Mike
Old 05-08-2007 | 01:28 PM
Well, I have the brand new alternator from Rover Connection.com in my 95 Disco. It seemed to fit and install with no problems. Drove the thing around the block a few times last night and drove it in to work this morning and ...
AAARGH! [:@]
Dead battery!
The alternator seemed to be charging the battery just fine after installation, so I don't know what gives. There is a check engine light that comes on when the battery voltage gets low, but I don't think that will give me any helpful info. I'm going to have the battery tested just in case, but I'm running out of ideas. Please help.
Old 05-08-2007 | 03:08 PM
The check engine light won't help you, sounds like it is time to get it to a good Rover electrical mechanic.
Mike
Old 05-08-2007 | 03:50 PM
Oops.
I was in a panic needlessly. I assumed that something horrible had happened, but ...
The transmission was not fully shifted into park! [8D]Duh!
Thus, the car wouldn't start and the key would not release.
I'm an idiot ... but a very relieved idiot.
By the way the RoverConnection.com aftermarket alternator seems to be working beautifully.
JumPeR04
12-17-2009 07:57 PM
mgabriel
12-11-2008 11:53 PM
rinmud
08-12-2006 07:12 PM
lbvbroker
03-04-2006 01:28 PM
Meyer
05-26-2005 06:20 PM
Quick Reply: Alternator Short?
