am i headed in the right direction???
Old Jan 20, 2009 | 08:18 PM
calebmorphew's Avatar
6th Gear
Default am i headed in the right direction???
ok thanks in advance to any help
99 d1 140k
noticed a rattle like sound in the floorboard area when i am running around 45 mph to 55 mph cruising speed and when i let off the gas first thought was rear u-joints changed both of them hoping to fix the problem after changing the back drove it and still noticed the same rattling sound. Am i headed in the right place changing the front u-joints next to fix my problem or could i be overlooking something... when hearing that small rattle like sound i do not notice any vibrations in the drivetrain. Once i get up to 60 mph the rattle turns to more of a constant humming sound
frustrated d1 owner
Old Jan 20, 2009 | 08:23 PM
Default RE: am i headed in the right direction???
Well go ahead and change your front u-joints so that they match the rears in age, some things you always replace in sets, u-joints, tires, brakes...
With the engine off take a small hammer and crawl under the truck and tap on the catalitic convertors, if they rattle, and I am betting that they will, you need new cats.
The are right under the floor board's so I am betting that is the rattling that you hear.
Old Jan 20, 2009 | 08:32 PM
6th Gear
ok so as i am ordering u-joints what does code a and another u-joint that has code c,d
Old Jan 20, 2009 | 08:44 PM
I do not know what the different codes are.
Old Jan 20, 2009 | 10:14 PM
unimoged's Avatar
I had a very similar issue. What I did was the following:
[ul][*]Removed the front driveshaft.[*]Locked the CDL, had to do it by hand using an open ended wrench from below.[*]Drove the Disco with power supplied to the rear differential (2WD mode).[*]The humming noise was gone.[*]Ended up rebuilding the front driveshaft using 3 U-joints.[/ul]The U-joints used: MEYLE GERMANY, 514 814 0002, paid $36 for the set.
wrongway1
Jun 7, 2014 09:16 PM
screamin demon
Nov 12, 2012 10:41 PM
csansoni
Dec 14, 2011 12:26 PM
twotimeowner
Mar 20, 2010 12:02 PM
ScottJ
Jul 31, 2007 11:02 PM
