Am I right by assuming this is the 3 Amigos...?
Rough Road Signal Implausible P1591
It happened while driving on a flat as can be blacktop road under total normal driving conditions.
The check engine light is:
P1000(27) 02 Adaptive Mixture Correction TRA bank 1 &
P1000(35) 02 Adaptive Mixture Correction TRA bank 2
Also under ABS (cleared it too fast before getting to copy it down)... It said something like:
Front Passanger Speed Sensor Implausible
When the codes are cleared, it is going to take several cycles for all the monitors to go thru their readiness state. Now the 3 amigos, could show up anytime there is a fault.
This guy's offering could be useful if you don't have the kit to check out the ABS in detail.
https://landroverforums.com/forum/di...go-rent-75733/
