Am I right by assuming this is the 3 Amigos...?
Old Sep 22, 2015 | 01:05 PM
RSDEVIL's Avatar
Default Am I right by assuming this is the 3 Amigos...?
...? Thanks.
Old Sep 22, 2015 | 01:27 PM
cappedup's Avatar
Correct.
Read the codes and see what you've won..
Old Sep 22, 2015 | 01:36 PM
FlyingZebra34's Avatar
There are many ways to fix this, but pulling codes will be the first step. A lot of scan tools these days can do it.
Old Sep 22, 2015 | 01:54 PM
RSDEVIL's Avatar
Rough Road Signal Implausible P1591
It happened while driving on a flat as can be blacktop road under total normal driving conditions.
The check engine light is:
P1000(27) 02 Adaptive Mixture Correction TRA bank 1 &
P1000(35) 02 Adaptive Mixture Correction TRA bank 2
Also under ABS (cleared it too fast before getting to copy it down)... It said something like:
Front Passanger Speed Sensor Implausible
Old Sep 22, 2015 | 08:43 PM
RSDEVIL's Avatar
I cleared both the Service Engine and her 3 buddies, drove 30 miles home and no one has come back....??? Party's over...???
Old Sep 22, 2015 | 08:51 PM
Joemamma1954's Avatar
When the codes are cleared, it is going to take several cycles for all the monitors to go thru their readiness state. Now the 3 amigos, could show up anytime there is a fault.
Old Sep 23, 2015 | 03:43 PM
RSDEVIL's Avatar
Well the check engine light came back this morning. Only 2 amigos (ABS & TC) came back this afternoon.
Old Sep 23, 2015 | 05:41 PM
OffroadFrance's Avatar
Sounds like an ABS wheel sensor misreading the plate or even a defective sensor. It could also possibly be a wheel bearing badly worn and the wheelhub moving around.
Old Sep 24, 2015 | 08:11 AM
This guy's offering could be useful if you don't have the kit to check out the ABS in detail.
https://landroverforums.com/forum/di...go-rent-75733/
Old Sep 24, 2015 | 09:25 PM
RSDEVIL's Avatar
Ok so the two amigos went away again and then came back today...???
I rescanned it w my buddy's Snap-On scanner again and got these:
119 Front Left Sensor (output intermittent)
P1591 Rough Road Signal Implausible
