Amigo reader in/around Indy?
Old Feb 23, 2010 | 02:03 PM
iplayblues4u@comcast.net's Avatar
Default Amigo reader in/around Indy?
Thought I would check on here to see if anyone has the amigo reader in or around the Indianapolis, IN area. 3 amigos have been on for some time and the 'ol lady is starting to wear me out complaining about it :-). Hell, it might be worth the $150 or whatever it is to just buy one considering all the stuff I read on here about 3 amigos. Any way, holler if you got one.
Old Feb 27, 2010 | 04:34 AM
2001SE7's Avatar
Default What is it?
Just what is this 3 Amigos?
Old Feb 27, 2010 | 10:23 AM
ainiguez's Avatar
How far is Churubusco from you?
P T Schram is a frequent contributor to Discovery fora
P T Schram Rover Repair
Old Feb 27, 2010 | 07:06 PM
Jason_B's Avatar
The three amigos is an event in which the Land Rover Discovery II's ABS system is malfunctioning. The whole system trips when one little thing goes wrong. Once a hard fault hits, you have to have the Land Rover testbook to turn it off and to take it in and have it done it cost 120 at a dealer. The ABS amigo clears your codes and tells you whats wrong when you plug it into a pc.
Old Feb 27, 2010 | 09:33 PM
2001SE7's Avatar
It sounds like The Land Rover dealer is one of our closest enemies. Bastards!, oops!....well I guess it isn't swearing if it is true. So does Land Rover have a monopoly on that "testbook" thing; can places like Autozone help? When this does happen does it become clear why it is called "amigo" ? Cause I'm still a little dafussed with that.
Old Mar 1, 2010 | 08:06 AM
Churubusco is around 2 hours north east of where I live. I had never even heard of the city...had to look it up on Google Maps.
Old Mar 1, 2010 | 11:22 AM
Wolkesan's Avatar
In Indy? Yes, LR pretty much has a monopoly but Euro MotorWorks on 90th St (317.595.9272) might have testbook. If they do they probably won't be any less expensive than the dealership. Autozone won't have anything.
The lights are called the three amigos because they always show up together. The ABS Amigo is called that because it diagnoses and clears the "amigos" not to mention it is your amigo (friend) if you ever need to clear out the ABS codes.
I'm going to be purchasing the Hawkeye diagnostic tool. It has been too cold to work on anything and I have had too much going on. I'll post when I do and see if you still need the codes cleared.
Old Mar 2, 2010 | 10:32 PM
2001SE7's Avatar
Wolkesan,
will this Hawkeye diagnostic tool diagnose and clear the "amigos"? How much is a Hawkeye diagnoses tool? Are there other affordable "Amigos Readers" available to the home DIY mechanic. I have seen OBD readers that are available for the majority of automobiles; is the Hawkeye tool capable of diagnosing Land Rover OBD and Amigos as well as other manufacturers?
Old Mar 3, 2010 | 10:34 AM
Wolkesan's Avatar
You can read about it here: http://www.dap-inc.com/hawkeye/index.shtml
I use a ScanGaugeII as my OBD tool because I like to be able to monitor water temperature along with other data as I drive, but no OBDII code reader can access the proprietary Land Rover codes. (ABS being one of those systems)
They Hawkeye will cost you approximately $600. Not cheap, but when you figure each trip to the dealer will cost you over $100 just to read the codes and you might have to make multiple trips, it isn't that bad. It also allows you to do a lot of diagnostic work on your own that you otherwise could not do. Helps you not throw money at unneeded parts.
ABS Amigo works well and is less money, but it only resets and gives you the ABS codes. To me it is worth the extra money to get more functionality.
Old Mar 8, 2010 | 10:32 AM
asianq's Avatar
BlackForest motors on NE side of Indy...Highly recommend when I lived there. They did an excellent job on my 02 Range Rover and 00 Disco. Don't take to Tom Woods.... They are a "Ripoff"!!!!
