Another Dumb Oil Question
Hey Guys,
I know this subject has been beatin to death, but I see a lot of Disco owners using Rotella 15/40 oil. I live in the North East (Maine) Going to do a oil change as soon as it gets above 5 degrees !! Question I ask I see it avail at Advanceed auto store but it says heavy duty diesel oil either T-5 or T-6, is this the stuff I want ???
Thanks again- this website saves me at least once a month if not more !!
Hey Guys,
I have seen some "heavy duty diesel" stuff. You might consider the $13/gallon Rotella T5 15w-40 from Walmart. Advance auto is like $18/gal. O'reilly had a $13/gal special too.
If you're comfortable with full synthetic, some guys like the T6 5w-40 for cold start climates in winter.
http://www.walmart.com/ip/Pennzoil-R...1-gal/44981490
I'm educating myself on oil also. T6 is full synthetic. T5 is a blend. I am about to switch to T5 15w-40 because it does not get down to 0F here in Texas. Cold start climates, folks go T5 5w-40 usually winter and 15w-40 summer. Also extra capacity filter like Mobil 1- M1-301 or Wix 51515.
Rotella T5 15W-40 Motor Oil, 1 gal - Walmart.com
T6 is full synthetic 5w40.
T5 is synthetic/dino blend 10w30.
Then standard Rotella T (full Dino) is the 15w40.
Thanks! I thought T5 was various weights. I see now it is not.
Honestly oil is oil for the most part and as long as you use the proper weight and change it per the owners manual. You should be fine, however as our LR's are getting older oil requirements are changing for the newer car engines and they're adding less and less Zinc. The engines in our D1/D2's is based of a 60's Buick 215 design and they require an oil with Zinc.
I started using Rotella 15/40 in my 05 Jeep Wranglers with the famous 4.0L I6 which once again is an engine design from the late 60's. I like it, for it's price, availability, and it's a very clean oil.
