Another electric fan conversion, for $70.
I just got my electric fan conversion completed yesterday and here's what I did. I used a fan from a 95 Mustang. This one was out of a 3.6, but I believe they were used in all 94-95 mustang models as well as all 94-95 Fords/Lincolns/etc that had the 3.6 V6. There are two different shrouds from what I saw, mine is the one with one corner cutaway. There are also two different fan blades, one with more blades and one with less. I opted for the the one with more. It looked like this.
And here it is installed.
Very simple installation. Remove your fan shroud and mechanical fan. Use the fan clutch tool from O'Reilly auto, you'll need the 58 mm wrench to hold the bolts and the 36 mm wrench to actually turn the nut. Once you break it off it just spins loose.
Now, you'll either have to make some top mounts or you'll have to drill a hole, in the top corner of the shroud that doesn't have one and use the pull through style. I don't like to use them, but I am until I can fab up some mounts. The bottom will sit right in the two factory fan mounts without issue.
For wiring, I didnt even bother with a controller. I went from the inside cigarette lighter, hooked it up to two relays (one for each speed), and then hooked up both of the fan speeds so it's always on as long as the vehicle is. I do plan to eventually install a controller for the higher speed, but for now this lazy method is working fine. And viola! All done.
I'm getting temps equal to the factory mechanical fan at idle but lower on the 4 lane at 60. With the factory radiator, factory water pump, and an OEM 190 stat (which I'll be replacing with an in line 180), it was sitting between 195 and 197 on the interstate, but even dropped to 188-190 a couple times. At idle she was sitting 201-203 which is where I was before. Oh, and it was 85 degrees and sunny.
I'll also be installing an oil cooler using the trans cooler out of my 04 parts truck, so that should help that much more.
Said and done I spent $70 on this, but I already had the relays and all the wire. These fans are plentiful on eBay, I recommend checking them out.
Thanks Racer. Yea, it is the 3.8 version. It said on eBay that it was compatible with the V6, GT, and Cobra, but the seller might have been mistaken so thanks for that.
There are actually a couple Taurus fans on eBay which is what I was originally looking for, but they seemed to be a decent bit more expensive with nothing different other than the shroud not having a cut away, but I could be wrong.
