Another electrical mystery...
Old Mar 20, 2019 | 01:16 PM
jamestfl's Avatar
Default Another electrical mystery...
2000 D2, 165k mi, owned about 4 years. So, a couple of months ago I get a dead battery, UG says voltage running about 14.5 at start. Replace battery, still have high voltage. Always ran about 12.4-13.2 since I owned it, and that's with battery and alternator changes. Very consistent voltage, no issues. Even after new battery and new alternator recently, voltage running high and overnight battery drain. I put a ground cut out switch thingy in it. Now I'm seeing the UG blank out and reset, for no apparent reason. Where to start with diagnosis? ECU?
Old Mar 20, 2019 | 04:06 PM
mollusc's Avatar
14.5v is not high -- that's where it should be when the engine is running and the alternator is charging properly.
Old Mar 20, 2019 | 05:45 PM
Best4x4's Avatar
I see 14.1-14.4V when it’s charging. It’s the 14.5-14.9V stuff I’d be worried about unless you drive an LR3 (they seem to charge higher vs D2/P38’s).
Old Mar 20, 2019 | 06:39 PM
Motorhead1's Avatar
Every once and a while I'll see my UG blank out and reset, it's done that since new...
Old Mar 20, 2019 | 06:47 PM
Best4x4's Avatar
My Scanguage II will sometimes take forever to sync up, but once it does it’ll never go out till I turn off the ignition.
Old Mar 20, 2019 | 06:57 PM
jamestfl's Avatar
All good points so far, thanks guys. It's the battery discharge overnight that really makes the situation difficult.
Old Mar 20, 2019 | 07:42 PM
Saturnine's Avatar
Get / make a test light and see what circuit is causing the drain!
Old Mar 20, 2019 | 07:48 PM
redwhitekat's Avatar
I had this problem my ultra gauge would drain my battery
there is a low voltage cut out on the ultra gauge itself I think I set it to 12 v to shut off
it might also have a high voltage cut out not sure
but I would unplug it and see if your battery still dies
Old Mar 20, 2019 | 08:15 PM
bcurtman's Avatar
Now that's interesting. I've had a parasitic drain I can't find either. Eliminated SLS, charges 13.6-14.2 when driving, swapped in known good battery, and every now and then have to jump it. I carry a jump box in the back so never stranded. My ultragauge goes black when I cycle the key off... but it still draws?
Old Mar 21, 2019 | 10:58 AM
Motorhead1's Avatar
If you can't find an obvious problem after visually looking everything over, you need to do this ^. Remove your ground wire off the battery, put a 12v test light between the neg battery post and the body. Light should light up somewhat bright in your situation. Start removing fuses one by one to see which circuit puts the light out. That will be the circuit you'll need to really dig into to find your draw.
