Another Hard Starting Disco
Old Jul 18, 2012 | 06:39 AM
dc10freighter's Avatar
Default Another Hard Starting Disco
I did the head gaskets a couple summers ago on my wifes Discovery II and ever since its been intermittentantly hard to start (it takes probably 5 seconds of cranking to start). After the initial start it will fire right up untill it sits a while then its hard to start again.
I should say that most of the time its hard to start after it sits. Theres no rhyme or reason to when it is going to be hard to start and sometimes it starts right up. When it is hard to start it has a very strong fuel smell after it is finally running so it seems like its not a fuel problem, but then again what do I know?
Around the tailpipe it is very black and I just got new O2 sensors, so I hope that helps.
Any help or advice would be much appreciated.
Old Jul 18, 2012 | 07:09 AM
jfall's Avatar
Betting you have a CEL lit.
Betting you have codes pending.
What are the error codes?
Old Jul 18, 2012 | 10:35 AM
Thats the strange thing, no codes. I have had a P0441 and changed out the Purge Valve and that went away. Other than that nothing else and nothing pending according to the reader that I have.
Old Jul 18, 2012 | 12:51 PM
Fuel pump is most likely starting to fail.
Old Jul 18, 2012 | 02:01 PM
Mike-
So would you put a new fuel pump in, or check pressure first?
I guess I could get the guage on the rail (yuck) and see what the pressure loss is overnight.
What should I be seeing as far as fuel pressures? Its strange that its intermittent and started right after the head gasket job.
One other think you can hear it want to start, then doesn't catch cranks for another second and ignition!!
Thanks for the help
Old Jul 18, 2012 | 02:56 PM
So, for those times when you think it will be hard to start, turn the key, 3 times to the start position, #2 and back off, then try and start it and see if there is a difference.
Old Jul 18, 2012 | 02:59 PM
OK I'll try that, thanks.
Old Aug 4, 2012 | 09:06 PM
Mike
I tried the ignition, didn't seem to make a difference. I put the fuel pressure guage on the schraeder valve. I'm getting 46psi. After shutdown it leaks down pretty quickly to 40 psi, then a slow trickle down to nothing (2 hours). Also when I did the heads I couldn't get the 8mm wires and replaced my existing with 6mm wires. Do you think that could be making a difference?
Old Aug 5, 2012 | 07:38 PM
Rover De Land's Avatar
I'm thinking it's not fuel pump, due to it holding pressure well enough (though others might say its not) the the smell of fuel. And the key trick not working. I'm
Thinking more electrical, like a coil pack. Simply not sparking the first few times it's told to
Old Mar 25, 2013 | 09:35 PM
nels2173's Avatar
3rd Gear
I'm having this same problem, exactly the same, did you ever figure the root cause of your problem?
