another question re front cover gasket
Old Jun 26, 2013 | 11:54 AM
SuperSport's Avatar
Originally Posted by vwhammer
...Either way I had to change my front cover that was leaking and surprise there was silicone everywhere... ...It drives me crazy when tearing into an engine and finding globs of silicone on every single part when it is totally unnecessary...
I think you are right, they are designed to not fail. But also, the above statements are likely why you've seen failure. TOO MUCH, uneven, or dry, silicone.
I put a super thin layer on everything (EXCEPT head and exhaust gaskets) and assemble it quickly before the silicone has a chance to set up. I think operator error is the failure you are seeing. If it's too thick/uneven and not compressed enough, then that's a weak point. If it gets a chance to set up, then that's a weak point.
I've RTV sealed hundreds of gaskets, and never seen a failure yet. On the other hand, I've had originally installed dry gaskets fail. But, like you say, to each their own. I don't think you are wrong, I just try to go the extra mile while I'm in a job so I don't have to see it again.
Old Jun 27, 2013 | 06:36 AM
Marni's Avatar
OK, the RAVE says dry.
I've gotten opinions, backed with good logic, on both sides of the fence.
I think I'm going to follow the RAVE and go dry.
And if it leaks down the road, I will madly curse every LR engineer, as well as the writers/publishers of the RAVE!
Old Jun 27, 2013 | 03:47 PM
SuperSport's Avatar
That does sound like a well thought out decision. I'm sure you will be fine...
outdoor7or24
Dec 22, 2014 09:31 PM
tmtegt
Mar 20, 2013 07:31 AM
TRIARII
Nov 4, 2012 05:30 PM
