Another Temp Light/ Coolant/ heating thread
Old Feb 22, 2016 | 04:08 PM
UncleDirtnap's Avatar
Default Another Temp Light/ Coolant/ heating thread
Hello all-
I've had my 2002 D2 for about a month now. I bought it off criagslist - looked beautiful, 125K, super clean. A week in I discovered the 3 amigos lights covered with electrical tape, but otherwise it's been great.
Leaving nothing to chance, I've been doing the 120K service. It runs fantastic, but there has been an odd thing or 2. I went on a 4 hour drive, no problems. Next morning, I was driving it around my sister's neighboorhood when the temp guage went up, then down, and the light came on. It happened in the space of 5 seconds - it was halfway, it shot up and then almost instantly down. When I poped the hood, coolant was bubbling out. Let it cool, topped it off, everything good. Got a pressure tester, replaced the thermostat, found 2 little drips on hoses, and after leaving it pumped up I noticed that after 2 hours the pressure was down ever so slightly, and there was a dark sppot near the weep hole of the water pump. Order a new water pump.
Double check the coolant level constanly, but over the weekend I was running an errand and it did the spike crash red light dance again. Pull over, let it cool for a few hours, only this time I can't get the light off or the guage to work. The new oil is pristine, it still runs perfect, no codes, but temp guage just doesnt work now. Could the sender be shot? I've followed the bleeding procedure probably 18 times now....
Thanks for your wisdom - I'm going to find a head gasket testerm but I'm 99% sure I dodged a bullet. Needless to say, I had it towed and I'm not driving it until I get the water pump changed....
-rj
Old Feb 22, 2016 | 05:10 PM
drowssap's Avatar
The problem that you have is not unusual, and unfortunately the landrover temperature gauge doesn't help.
Be sure to pressure test when you finish the water pump. Frequently a pressure test will show the weakest link.
The problem with your gauge is either a bad sender unit or its in an air pocket.
That is why your gauge acted like it did, it has to be in water to read.
How high did you go with the pressure test?
ted
Originally Posted by UncleDirtnap
Hello all-
-rj
Old Feb 22, 2016 | 05:31 PM
I held the presssure at 20 psi-
Hopefully I'll find something conclusive when I tear into it tonight-
-rj
ted
Old Feb 22, 2016 | 05:46 PM
drowssap's Avatar
20 psi for two hours is pretty good.
-rj
Old Feb 22, 2016 | 09:21 PM
chubbs878's Avatar
You should really get an aftermarket gauge to monitor your coolant temperature. The factory gauge is inaccurate to begin with. It basically just has 3 positions, so when it does move to over-heating (on a properly functioning unit) then the coolant has been climbing up to some 230 degrees or so before it ever set the switch. This is a contributing factor to many a failed head gasket...coolant temps operating in the 220's and no signal from the "temp gauge."
When I first bought my D2 with no idea of the quirks, there were a couple of occasions when I saw steam before I saw the temp gauge move.
Old Feb 22, 2016 | 09:35 PM
I'll have to start checking out gauges- I've always had a obsessive instrumentation bent- I had a ultralight aircraft engine management guage in my old VW
On the happy side, I took the pump off. It is definitely shot, there is no goo or sludge, and the gasket even stuck to the pump side. It's like it's Christmas all over again!
-rj
Old Feb 22, 2016 | 11:50 PM
chubbs878's Avatar
You lucked-out on that gasket. Of course it's not a big deal when air compressor and tools are accessible to buff it off the block but I didn't have that luxury stranded in the AutoZone parking lot. I didn't have enough sense to buy an electric version like a Dremel-type; won't make the same mistake again.
FYI: tons of threads suggesting viscous-clutch replacement with new water pump. I have to agree, so if you have the means you should seriously consider this. More often than not, 1 fails shortly after the other. Better to go ahead and upgrade it to heavy duty version for better cooling with summer temps right around the corner
Old Feb 23, 2016 | 09:34 AM
I will take your advice - anything I can do to cool this beast down in the 100% humidity Florida heat is a good idea. Some things you just don't play around with-
-rj
Old Feb 23, 2016 | 10:46 AM
chubbs878's Avatar
-rj
you're smart.
Old Feb 23, 2016 | 12:29 PM
number9's Avatar
-rj
Most use OBDII scanner/gauge or phone app. Plenty of choices and +s/-s to each type or model. Partial to my dedicated ScanGaugell due to front nav buttons though it does lack an aural warning.
