antenna adapter question
Old Apr 21, 2022 | 09:56 PM
krustacean's Avatar
Default antenna adapter question
Hello. I am installing a new HU to replace the factory radio. I have the two antennae but neither of them fit in the rear of the the HU. It is the BOSS 616UAB unit. I am searching for the adaptor that can mate the old antenna with the new HU. Hoping to get some direction for the experts on here! thank you
Old Apr 22, 2022 | 06:40 AM
zski128's Avatar
You will have two antenna wires, one thick and one thin. You can take apart the end of the thick wire to reveal a plug on the end should fit the Boss. I just installed a Boss with a 9” touch screen.
Old Apr 23, 2022 | 07:40 AM
krustacean's Avatar
ok! I managed to get the antenna hooked up. No modifications needed. Now i have the HU working but it isn’t very loud! It might be something to do with the OEM amp.
Old Apr 23, 2022 | 05:57 PM
zski128's Avatar
Could be if you are wanting to use the stock amp. Not sure what harness you got but there is a wire for to enable the stock amp. In my Boss HU I had to disable the internal amp to clear up static and hissing noises.
Old Apr 24, 2022 | 01:21 PM
Discorama's Avatar
The enable wire for the stock amp makes it turn on and off. Since OP has sound, it works. In order to correctly install a new head unit with the stock amp, you have to use differential outputs (8-pin connector, not the RCA outputs with adapters). If he used the RCA outputs, it would explain the low volume. If he used the 8-pin connector, the HU should supply a sufficiently strong signal for the stock amp. I don't know if there is an adjustment option for this in this specific HU.
earlyrover
Apr 9, 2013 03:54 PM
kpl1228
Aug 8, 2012 10:49 PM
jeepguywithadisco
Aug 11, 2011 10:04 AM
jsuit
Nov 29, 2010 01:45 PM
Spike555
Jun 21, 2008 09:17 AM
