anti lock amber light on
Old Aug 25, 2008 | 12:13 PM
redhotbuzz's Avatar
Default anti lock amber light on
I have recently redone my front brakes,, new rotors,calipers,bearings,shoes and throw in brake pipes for good measure..The brake shoes are making a slapping sound when Istep on the brakeand the anti lock light is on are these two problems related??97 D1 LSE .... What a freakin ride why did i wait so long to get one... Thanks in advance Great forum......
Old Aug 25, 2008 | 01:45 PM
Default RE: anti lock amber light on
I am going to say yes, they are related. You have a loose brake pad and it is messing things up.
Double check your work.
Old Aug 25, 2008 | 02:08 PM
redhotbuzz's Avatar
I checked that already .Its seems that the caliper plungers and pads have play in them ..the plungers and pads only come into contact when I depress the pedal. I have changed fluid and bleed brakes
Old Aug 25, 2008 | 02:40 PM
Pull the fuse to the ABS from the fuse box under the hood and see if the noise is still there.
Old Aug 25, 2008 | 03:02 PM
redhotbuzz's Avatar
I pulled the valve pump fuse same results ..How do I get the pump valve off dont wanna break it ??
Old Aug 25, 2008 | 03:34 PM
I do not know. My '97 had the ABS problems with the truck not wanting to stop and it making a pulsating sound, pulled the fuse and problem solved.
Not sure what you have going on.
Old Aug 25, 2008 | 03:45 PM
redhotbuzz's Avatar
Spike..... Thanks.......I have saw on other posts you got same model as me.97 D1 LSE ,,,, whats the 1st buttom on panel left of foglight switch for ?my guess is Running lights But it looks like someone got mine ,,,I have2 wire lines hanging but cant get no power out of them they are black and blue with some kind of quick connect attached,,,,,,,, any thoughts?
Old Aug 25, 2008 | 06:15 PM
Left of the steering colum, switches, rear defrost, rear fog lights, now I have to go and look....
Top is rear defrost, next is rear fog lights, then stereo volume up and then down.
Old Aug 25, 2008 | 06:17 PM
AK Rover's Avatar
Buzz - I also have a 97 D1 LSE. Couldn't agree more with wondering why I waited to get one. I also have my ABS light come on periodically but there is no sound associated with mine and the brakes work great so I figure until I can afford to have it looked at I'll live with it. The switch you are referring to I believe is your master cruise control switch. In my D1 it is actually to the right of fog light but I believe it is the same switch. Or is there another switch in addition to the fog lights and cruise control? Any chance you could post a picture of the mystery switch? Do you have any extra lights or accessories such as that that could be operated by the switch?
Old Aug 25, 2008 | 06:25 PM
Sorry, I thought he said left of the steering coloum, my mistake.
Cruise control power switch and the fog light switch, thats all. But they have open spaces for extras. Do you have extra fog lights?
EJECTOR SEAT!!! Thats what it is for, the ejector seat for your mother in-law!
