Anti Theft Lights Keeps on Blinking
ORIGINAL: dikubec
My 97 Disco SE7 anti theft light is keep on blinking, no stereo not working and both front seats are not working also. Any ideas what's goin on? Thank you so much.
Mike
Check your fuses first. How long has this been happening, what were you doing when it started?
Take your key, put it in the drivers door and slowly lock and unlock the door 3 times, if it is the alarm, it should reset it.
Mike
Mike
Mike, fuse is okay. Try to reset the the alarm as you said, still blinking. It's started a bout two months ago. There will be a time that the anti theft light goes off and stereo start working so does the two front seats you'll be able to adjust them. Later of the day, it will not work again. I can not think off something that started this problem. Any other idea than I can try to do more troubleshooting.
Thanks a lot Mike.
Thanks a lot Mike.
rod97rvr
Dec 19, 2009 08:39 PM
