Antifreeze heater??
Old Dec 10, 2009 | 04:42 PM
devildog01's Avatar
Default Antifreeze heater??
Just wondering if anyone has or has heard of using an inline antifreeze heater on a disco.I have heard they work well because they keep the antifreeze warm and circulate it around the radiator and block.Thought it might work well for winter.
Old Dec 10, 2009 | 05:12 PM
lipadj46's Avatar
Like this?
http://www.roverparts.com/Parts/PRC9674G.cfm
I personally have never have used a block heater but I do regularly use an oil an heater in the winter. They are only $25 and work really well on cold starts in the winter. Here is the one I use:
http://www.northerntool.com/webapp/w...9139_200339139
Old Dec 10, 2009 | 05:36 PM
devildog01's Avatar
Originally Posted by lipadj46
Like this?
Do you put it on and leave it on? If so were exactly did you put it (ie oil pan) and how/were did you mount the plug?
Old Dec 10, 2009 | 05:46 PM
lipadj46's Avatar
The block heater goes in a freeze plug hole and the oil pan heater sticks on the oil pan (via adhesive). I have the plug zip tied under my running board.
Old Dec 10, 2009 | 05:56 PM
devildog01's Avatar
Cool thanks for the info Im gonna pick up the one from northern and try it out.Im guessing you just clean the oil pan off really well then stick it on while the pan is warm/hot?
Old Dec 10, 2009 | 06:07 PM
lipadj46's Avatar
On a DII you have to stick it on the side of the pan because the bottom is ridged. But once you clean and degrease the pan it just sticks on via a peel and stick and then you use some black RTW to seal the edges.
Old Dec 10, 2009 | 06:28 PM
Why do you feel you need one? Until you go under -35 or so it is a waste of money and maintance to keep it going, if you had a diesel, that would be another mater.
Old Dec 10, 2009 | 06:42 PM
devildog01's Avatar
It doesnt get that cold here but for $25 bucks its easier on the engine on start up to have warm oil instead of molasses in january.Ive had block heaters and antifreeze heaters on most of my heavy equiptment and it makes all the difference in the world on start up when its cold out.
Old Dec 10, 2009 | 06:46 PM
lipadj46's Avatar
I never said you need one, at least I don't, but it does helps on cold winter mornings with startup. Also consider that most wear happens at startup and it can't hurt so have your oil a bit thinned to help it pump to the top end and flowing faster. I like that I can use a little thicker synthetic in the Buffalo winters because my truck runs a little better with thicker oils. I keep mine on a timer to go off for 2 hours before I leave in the mornings. Figure it costs the same to run a couple light bulbs for an hour or two.
Old Dec 10, 2009 | 09:15 PM
Block heaters are a good idea if you live where it gets cold.
I am partial to this one, it is easy to install.
http://cgi.ebay.com/ebaymotors/katt-...Q5fAccessories
It goes in your lower radiator hose and it heats your coolant, start the engine and instant heat.
