Any luck with aftermarket key fobs?
Old Feb 9, 2016 | 03:14 PM
back9sunday's Avatar
Default Any luck with aftermarket key fobs?
Hello all,
I just purchased two new aftermarket key fobs. Just got off the phone with my British auto specialists and they told me only OEM key fobs were eligible to be programmed to work on my '02 disco. But then again I've read success stories of ppl buying aftermarket and getting their keys to be programmed and work. Can anyone shed some light into this issue?
Thanks
Old Feb 9, 2016 | 03:24 PM
Dave03S's Avatar
Key's in Disco's are not programmed. There is no chip.
There is the RF signal that unlocks the car but I bought an aftermarket key fob shell and used the existing circuit board from inside my original fob so it was plug and play...
Except it took me two tries to get a key cutter who could do the job right and it is a bit futzy getting the metal part of the key out of the original plastic fob shell.
Old Feb 9, 2016 | 04:00 PM
jamieb's Avatar
Just ordered 2 off ebay for my DII. Opened them up, swapped the guts from one FOB to the new one and snapped it closed. With pliers, I removed the key blade from each FOB and put the old blade into the new FOB. One was a tad loose so a drop of elmer's glue locked it in. (Didn't want too permanent a glue).
Remote Key Shell Fob for Land Rover Discovery 1999 2004 Fob 2 Button Repalce | eBay
Replace the key blade:
Works awesome. I tried to cut the keys at a hardware store but it did not work so well. They recommended a lock smith. I just pulled the blade out and all was well.
Old Feb 10, 2016 | 07:10 AM
drowssap's Avatar
there is no after market remove that works, it you have a remote it can be repaired with parts from ebay.
if you need a remote, do a search someone just found a company that will send you a new remote programmed for like $150.
i think the post was "ordered a key and fob for d2 and they work"
foobar
Jul 4, 2015 11:35 AM
Braxo
Aug 19, 2012 05:22 PM
Chris-bob
Aug 31, 2011 08:47 PM
andyl0183
Sep 27, 2009 01:17 PM
lk311
Nov 25, 2008 10:29 AM
