Any secret to loosening the fan nut?
Old Nov 3, 2015 | 09:15 AM
swak6287's Avatar
Spray some liquid wrench
Old Nov 3, 2015 | 09:32 AM
Jagfixer's Avatar
Reverse threads, right is loose, left is tight?
Old Nov 3, 2015 | 09:47 AM
drowssap's Avatar
you know that one of those thing i never think to remind people, that its left hand thread
Old Nov 4, 2015 | 11:43 AM
batard's Avatar
I haven't been having much luck with a bigger hammer, but I soaked it in penetrating oil and will try again tomorrow.
How would doing it with vise grips work? Would you put them on one of the pulley bolts? I managed to slip on a 10mm wrench and extended the leverage, but I didn't go too hard on it because I was concerned about over-torquing the bolt.
Wedging a screwdriver in the idle pulley didn't do much. The pulley slips on the belt fairly easily anyway. Prying up against the back of the pulley with a crowbar also didn't seem to prevent it from moving.
Old Nov 4, 2015 | 02:34 PM
batard's Avatar
I've got it off finally. Thanks to all for the help.
After waiting for a while for the penetrating oil to set in, I couldn't resist giving it one more go today. An authoritative crack with a heavy metal hammer on the end of the fan wrench did the trick. I wasn't securing the pulley with anything when it came loose.
Now I have to sort out how to pull the bracket stud that holds the heater hoses on the passenger's side of the intake manifold. I have a stud puller set, but this one is super-small. Hmmm....I think I'll run two nuts on there and try to pull it that way.
Old Nov 4, 2015 | 02:39 PM
cappedup's Avatar
Did you hit it left, or right?
Old Nov 4, 2015 | 11:19 PM
batard's Avatar
Hit it left (normal loosening direction). I think the penetrating oil helped. I'd also say make sure you're holding it so there's no play between the wrench and the bolt, and don't be too gentle with it.
Old Nov 5, 2015 | 08:13 AM
cappedup's Avatar
Originally Posted by drowssap
.....to remind people, that its left hand thread.
I only asked because..
Old Nov 7, 2015 | 02:29 AM
Fallstaff's Avatar
Rovers north has a nice vid of replacing the power steering pump that shows a lot of this. Good reference.
Old Feb 14, 2017 | 07:52 PM
JUKE179r's Avatar
Watching both of these videos prepares me to tackle the removal/replacement of the viscous fan and pulleys. Remember... 36" wrench...
