As anyone actually changed a crank position sensor?
Old Mar 5, 2014 | 12:12 PM
toad2's Avatar
Default As anyone actually changed a crank position sensor?
I have it unbolted, but how in the world do you reach up and unplug the connector? I have small hands but can't even see it.
Remove the pipes?
Thanks in advance.
Chris
Old Mar 5, 2014 | 01:28 PM
dusty1's Avatar
i think I saw a pic of some dude cutting a hole in the inner wheel well. did mine while I had mani and pipe off, for repair
pics in here https://landroverforums.com/forum/di...ll-tips-58374/
Old Mar 5, 2014 | 01:42 PM
primussucks's Avatar
i dropped the y-pipe.. total PIA job..
Old Mar 5, 2014 | 02:23 PM
DiscoJ's Avatar
I remember inlisting the help of a long skinny flat head screwdriver to unlock/disconnect the connector. The overall process was a pain but I was able to do it without removing anything else.
Old Mar 5, 2014 | 02:40 PM
toad2's Avatar
thanks guys
Old Mar 5, 2014 | 03:21 PM
Dane!'s Avatar
That took me like an hour to figure out that the actual plug has a seat. After I popped it out of the socket it came off real fast, although, I do not have it back in its seat anymore, I couldn't get it back it
Old Mar 5, 2014 | 06:46 PM
toad2's Avatar
Got it off, had to drop the y-pipe. Didn't want to break the connector or the wires.
New one will be in 2morrow, i hope.
Old Mar 5, 2014 | 10:12 PM
tuercas viejas's Avatar
Tip
Remove the 8mm x 12,5 bolt holding the forked clip to the back of the cylinder head.
GENTLY pull down the pigtail section of the sensor which should be hanging out of the flywheel case aperture.
Unplug the sensor!
Carefully plug the crank sensor socket back into the harness connector. Refit as a reverse exercise. Beware you can mis-align the pins and push them out of the harness socket if you are clumsy--Then it will never start without a very involved repair behind that cylinder head and valve cover.
T/V
Old Mar 6, 2014 | 02:28 PM
toad2's Avatar
Just got everything back together and it started right up. Only broke the two bolts in the y-pipe.
Why would they use 2 studs and 1 bolt instead of 3 studs? oh well.
Old Mar 6, 2014 | 02:30 PM
toad2's Avatar
See you are a bubbles fan, can you watch Trailer Park Boys in Dallas?
