Anyone fitted boost alloys to a Disco 2? with adaptations
Old Oct 26, 2019 | 08:06 AM
Roby466's Avatar
Default Anyone fitted boost alloys to a Disco 2? with adaptations
I have a 2004 D2 with the original 18in wheels. I also have 5 boost alloys with MTs mounted on them from my 110 before I sold it.
Has anyone fitted the D1 or Defender wheels to a D2 using spacers-adaptors?
If so, what did you use? Did you have to cut the studs? Any pictures?
Thanks
David
Old Oct 26, 2019 | 08:35 AM
You would need a wheel adapter likely custom to switch to the much larger 110'bolt pattern
Old Oct 26, 2019 | 12:16 PM
ZGPhoto's Avatar
I've seen the adapters to go the opposite way(d2 wheels on defenders), but I haven't seen Defender/D1 wheels on d2s.
Old Oct 26, 2019 | 01:13 PM
Roby466's Avatar
I have seen them the other way too... I was looking at the wheel offset and it appears the Defender wheel has less offset than the D2 wheel, which would mean there would be room for the adaptor... I was hoping somebody had done it. I will look for adaptors and see if they exist. I cannot fit MTs on my 18in and would love the 16in I already have with the MTs on... only other option is another Defender but they are a bit more pricey over here
markdeg
Apr 25, 2018 10:51 AM
coors
Jan 7, 2014 06:53 AM
wcr4x4
Dec 5, 2013 11:21 AM
TRIARII
Feb 13, 2013 10:51 PM
85Red110
Defender
May 1, 2012 10:25 PM
