Anyone have a dead transmission from a drive shaft failure?
Old 02-22-2019, 02:16 PM
Ben Matheson's Avatar
Default Anyone have a dead transmission from a drive shaft failure?
Might need to replace a solenoid in mine and an otherwise useless tranny would have what I need.
Old 02-22-2019, 05:00 PM
zuke's Avatar
Jeez Ben .I have been following your posts about all you have done. What did you buy? The cursed Rover from the black lagoon?
Old 02-22-2019, 05:39 PM
I was actually going to do a whole write up on my journey. Essentially it was an unloved Disco with a blown motor that someone bought had the motor completely rebuilt and decided owning a Disco wasn't for them.
So i essentially bought a clean rust free frame with a new motor. Surprisingly everything worked and one new hub chased the amigos away. I've put new tires new drive shaft new brakes and rotors new springs new shocks new drop Link and bar new ball joints.
Next weekend she will get new compressor new condenser and a new steering box.
Still has the original gas cap lol
For now
Old 02-22-2019, 05:40 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Normally when the driveshaft goes BOOM it will ruin the casing, solenoid pack, and pan.
My 99 D2 has scrapes on the casing/pan along with small dent in the floor, but she was lucky & no serious damage was done (happened before I bought it). I stand pretty firm with the removal of the lower front support. If the shaft goes BOOM it has a much better chance of dropping low enough not to hit the transmission. With that brace in place the drive shaft will just bounce off of it and straight into the transmission.
Are you looking for an HP22 or HP24 solenoid pack? Will over on Discoweb is selling complete HP22/HP24’s with a lifetime warranty for $250.00.
User (02-22-2019)
Old 02-22-2019, 07:59 PM
Mine is an 04 so it should be a 24. Thanks for the heads up on the parts
Old 02-22-2019, 09:56 PM
Best4x4's Avatar
No Problem!
Old 02-23-2019, 02:05 PM
Dsport's Avatar
hahahaha
Old 02-23-2019, 10:21 PM
scotod's Avatar
2 weeks ago, beat my trans bad,bought a good used one for $ 500.00,delivered, knocked trans. pan off, and did some damage to Y-pipe,not fun
Old 02-24-2019, 12:25 AM
Dsport's Avatar
bummer, sorry to hear that :/
Upon reassembly it may be a good idea to remove your front crossmember. It’s the cross member that keeps the driveshaft up allowing it to whip around and take out your trans. I had to remove mine anyway due to my lift, but I’d probably pull it out anyway.
cogsley
10-29-2015 02:14 AM
LRJtech
03-21-2015 03:30 PM
Smug
02-12-2014 12:48 PM
xxdoylexx
11-18-2013 12:09 PM
DiscovermeNOW
04-09-2012 11:59 AM
Quick Reply: Anyone have a dead transmission from a drive shaft failure?
