anyone have stock 00 discoII rim data?
Anyone have the stock data for the 16"ers rims for a 00 disco2? all ive found are the stock diameter obviously, bolt 5x120mm and a possible but unconfirmed 7" width? is the stock material alum or steel btw?
I'd like to compare them to aftermarket and steelies. Ie. bolt patter, backspacing, width and if possible, weight.
I was looking at okoffroad.com steelies that list 16x8 and 4.75 backspace and 5x120mm bolt pattern.
im guessing the backspace is different as it says they are designed to run with different tire sizes without radius arm rubbing etc. im guessing that means they stick out further then stock... so any idea what kind of tire size i coudl go with with them and the 3" terrafirma lift i just got in the mail?
thanks all!
thanks all!
IDK the backspacing, but the width in the stock D2 "Mirage" style wheels is 8".
I have the same lift and run 235/85r16 because I feel like they do a little better in the snow, but you can easily run a 265/75r16 on the Mirage wheels. Either the 235's or 265's are very nearly a 32" tire (diameter could vary a little depending on tread type and make...my tire size calculator calls then ~31.7") and fit nicely.
Depending on the width, I'm confident you could even go to a 33" tire before you start running into problems requiring you to start trimming things...
Disc03
02-28-2008 12:49 PM
