Anyone on here have an 04 HSE?
Old Nov 26, 2011 | 07:07 PM
toad2's Avatar
Default Anyone on here have an 04 HSE?
It says in the owners manual you can lower the SLS with a handheld remote. Just wondering how well it works and how much it lowers? Thanks
Old Nov 26, 2011 | 09:40 PM
It lowers 6", it will also lower if you open the door with the engine running and then raise back up once you shut the door.
It is to aid in loading the cargo area and hitching up a trailer.
Old Nov 26, 2011 | 09:45 PM
Perhaps the info you seek can be found in this passage from the RAVE shop manual (free whole set below):
The remote handset is an accessory item which allows the SLS to be operated between normal ride height and bump
stop height to allow easier connection and disconnection of trailers. The remote handset is similar in appearance to
that of the remote door locking handset but does not have an integral key. A circular button with an arrow is used to
raise the SLS and an oval button with the 'Land Rover' logo is used to lower the SLS.
The remote handset control requires all doors to be closed and the ignition to be in position II, but the engine does
not need to be running.
Pressing the lower button will signal the SLABS ECU, via the RF receiver and the BCU, to energise the exhaust valve
and air control valves. The SLS will lower up to 60 mm (2.36 in) below normal ride height if the button is held. If the
button is released the SLS will stop at that point.
Pressing the raise button will signal the SLABS ECU, via the RF receiver and the BCU, to start the compressor and
energise the exhaust valve and air control valves. The SLS will raise to normal ride height if the button is held. If the
When raising or lowering the SLS using the remote handset, the SLS warning lamp will flash and the audible warning
will sound when the system is operating. When the SLS is fully lowered the warning lamp will stay illuminated. The
SLS will reset to normal ride height if the vehicle speed exceeds 3 mph (5 km/h) for 10 seconds when the SLS is
lowered.
Old Nov 27, 2011 | 07:28 PM
toad2's Avatar
Thanks guys, I did not know it would lower with out the handheld and the rover shop up here did not know how to program a new one. I haven't bought my 04 yet but i hope to pick it up next week.
Old Nov 27, 2011 | 08:06 PM
jafir's Avatar
You program the SLS remote just like the keyless remote. When programming it on my scanner, it asks if the barcode I entered was for an SLS plip.
Old Nov 27, 2011 | 08:16 PM
toad2's Avatar
You can program the remotes yourself on a code reader/scanner ? You guys know more than the rover shops!
Old Nov 27, 2011 | 08:58 PM
jafir's Avatar
You need a rover specific scanner to do it.
Old Nov 27, 2011 | 11:27 PM
bosshogt's Avatar
This is the FOB you looking for. It does have to be programmed by a dealer or someone who has a Hawkeye.
Land Rover Discovery 2 / II - Suspension / EAS Genuine ... (Fits: Discovery)
Old Nov 29, 2011 | 03:47 AM
toad2's Avatar
Thanks again guys.
Old Nov 29, 2011 | 07:16 AM
drowssap's Avatar
there should also be a button on your dash panel that allows you to raise and lower it manually, has a pic of a truck with an up & down arrow in the back.
