Anyone try these? Window regulator repair
So I’m pretty sure I have a window regulator that has tanked, and I was thinking this might be solution. The window goes down just fine, but won’t go back up unless I pull the panel and kinda reach in there and help it go up.
I’ve not fully removed the door panel to inspect, but I suspect it is the roller(s).
Any thoughts?
I also found these: https://www.shapeways.com/product/ZQ...aign=affiliate
from a thread here. Anyone know if those are still available as an alternative the above?
Discorama (12-30-2022)
longtallsally (12-29-2022)
The following 2 users liked this post by Extinct:
adolfojbonilla (01-16-2023),
What adhesive or cement do you use for the Shapeways rollers? I tried them twice a few years ago but they came apart after a while. I don't now recall what adhesives I used, but in the end I just ordered a new regulator.
longtallsally (12-30-2022)
Plus, unlike the door lock actuator, a a window regulator is pretty cheap.
