Anyone try these? Window regulator repair
Old Dec 29, 2022 | 04:06 PM
longtallsally's Avatar
Default Anyone try these? Window regulator repair
Amazon Amazon
So I’m pretty sure I have a window regulator that has tanked, and I was thinking this might be solution. The window goes down just fine, but won’t go back up unless I pull the panel and kinda reach in there and help it go up.
I’ve not fully removed the door panel to inspect, but I suspect it is the roller(s).
Any thoughts?
Old Dec 29, 2022 | 04:11 PM
I also found these: https://www.shapeways.com/product/ZQ...aign=affiliate
from a thread here. Anyone know if those are still available as an alternative the above?
XRAD's Avatar
probably a cracked roller.....the replacement regulator mechanism is inexpensive...
Old Dec 29, 2022 | 05:09 PM
Yeah I just saw on Rock Auto they are like $50. I think I’ll just do that. Thanks.
Old Dec 29, 2022 | 06:36 PM
Extinct's Avatar
I use the shapeways parts, they work great.
Old Dec 29, 2022 | 06:45 PM
I thought I’d do the Dorman one? It’s $66.
Old Dec 29, 2022 | 06:53 PM
whowa004's Avatar
I got a used one from Jordan haha but it's been working fine for a few years now..
Old Dec 29, 2022 | 08:37 PM
He’s where I got the dash. But at well under $100, worth it to buy new I think.
Old Dec 30, 2022 | 09:27 AM
mln01's Avatar
What adhesive or cement do you use for the Shapeways rollers? I tried them twice a few years ago but they came apart after a while. I don't now recall what adhesives I used, but in the end I just ordered a new regulator.
Old Dec 30, 2022 | 09:43 AM
Yeah, it’s kinda like the door lock actuator. Yes, you can rebuild it, but in the end it’s just easier to replace the part. Yes, it’s lazy in some regards, but at this point, I’m using it a lot and just want things to work. If the original worked for ~20 years, I’m good with that.
Plus, unlike the door lock actuator, a a window regulator is pretty cheap.
