it says:
2003-04 WINCH BAR AIRBAG APPROVED, RECESSED INDICATORS1 , RECESSED FOG LAMPS2 , TOW POINTS3 , BLACK XD9000, M8000 3432120
1999-02 WINCH BAR AIRBAG APPROVED, RECESSED INDICATORS, URETHANE BUFFERS, TOW POINTS, BLACK XD9000, M8000 3432060
1Combination indicator/parking lamp supplied. 2 Uses original equipment fog lamps, if supplied. 3 Uses original equipment tow points.
Can anyone confirm that you can use the earlier 3432060 Bumper on a 2004 - I think I prefer the 99-02 bumper with the Tow Points (I know they are not very sturdy if anything like Jeep TJ ARB bumpers)
Concur, it will fit. However, realize there will be an appropriate two inch gap below the grill. The 99-02 grills are that much deeper. Actually good for improved airflow to radiator, just be aware there is a gap.
If reversed, and you were fitting a 03-04 ARB onto a 99-02, you would have to trim two inches off the grill, or fit a 03-04 grill onto the 99-02 model D2.
