ARP Head Studs
Old Mar 12, 2016 | 02:00 PM
  #21
number9's Avatar
Same question came up when researching parts for HG R&R. Read from several forums found doing a web search. Apparently there's a difference in hole/thread depth between the old/new blocks. Updated kit apparently has the correct longer length fasteners and the one recommended by ARP for the application. Reasonably priced with 20% off coupon, ARP 157-4301 Head Studs w/12-Point Nuts | Autoplicity and/or Lucky8 prices good too.
Most of same threads debate whether it's worth the extra cost when older kits seldom pull the threads out of the aluminum block if lower than recommended torque used.
Old Mar 12, 2016 | 02:01 PM
  #22
Joemamma1954's Avatar
Originally Posted by Best4x4
I'm about to get my head gaskets replaced on my 02 Kalahari with 225K on it for routine regular maintenance. I'd like to go with the ARP stud's but according to AB you aren't supposed to use the cheaper 124-4003 kit with the composite head gaskets.
What in the world is the difference between the 124-4003 & 157-4301 kit? I just want to make sure I just don't save $100.00 on the studs and then cause my head gaskets to go out prematurely.
Any info or input would be greatly appreciated.
It is the length of the studs. The 4301 are made for our engines. You risk pulling the threads out of the block. Use a thread cleaner, not a tap, before hand.
Old Mar 12, 2016 | 02:09 PM
  #23
drowssap's Avatar
I believe it was Zack from Rover North and the guys from Lucky that measure up the two sets not finding any difference in the post I read. But I've wrong before
Old Mar 12, 2016 | 04:29 PM
  #24
I read somewhere in my search, the studs did not come high enough. But like you, I have been wrong before also.
Old Mar 12, 2016 | 04:34 PM
  #25
Just did a search, and on pirate4x4 forum, the consensus was there were more threads on the block end for less chance of destroying the block threads. Some members pulled the block threads and had to heli-coil. Cheapest I found them was 179.00. I will go with these when the hg have to be replaced.
Old Mar 12, 2016 | 04:57 PM
  #26
Charlie_V's Avatar
Originally Posted by drowssap
I have not checked the # from phone.
But LR changed from 14 to 10 bolts in the later head. If one # is for LR and the other is for a 215 Buick that could the difference.
The Buick by the way fits and you get 8 more studs and are cheaper go figure.
Lucky 8 has the best deal I could find but it doesn't say which ones they are, if there is any difference at all.
http://www.lucky8llc.com/Products.aspx?ProductID=7471
Old Mar 12, 2016 | 05:39 PM
  #27
Charlie_V's Avatar
Where is the coupon?
Is 12pt the way to go? I use my 5/8th impact socket on them and it is 6 sided. I'm sure I could find another socket.
Old Mar 12, 2016 | 08:07 PM
  #28
Best4x4's Avatar
Okay I have found the 4301's for under 200.00 so that's fine with me. I just want to do the best head gasket job possible. My friend that's going to help me do the head gaskets says to just use the normal LR bolts, but I want the best results.
Old Mar 12, 2016 | 08:49 PM
  #29
Get the Fel-Pro MLS head gaskets and use the copper coat gasket spray, keep your temps below 200 and should be your last hg job.
Old Mar 12, 2016 | 08:53 PM
  #30
number9's Avatar
Sorry about the coupon, see it's only off shipping?
12pt sockets are readily available and should already be in your box. 6pt stud nuts another option.
My thought and paid the higher cost. Liked studs being reusable in the event of having to do HGs again down the road.
