ARP Thread Chasers
Old Oct 23, 2014 | 08:04 PM
coors's Avatar
Default ARP Thread Chasers
Has anyone actually used a thread chaser prior to installing studs? And which one is required for the 4.0 block.
7/16" - 14?
ARP Kit number 911-0004?
Old Oct 23, 2014 | 10:28 PM
04duxlr's Avatar
The bolts are 7/16-14. When I did the heads on my truck I took an old bolt and cleaned the threads up with brake cleaner then threaded them into each hole to check and see if they were clean. Every one went in with zero effort so I skipped the thread chaser. If you can seem to get them looking spotless with brake cleaner then you might need to use a chaser. Make sure there is no oil in the threads in the block if you are using the ARP studs. I went with stretch bolts as I believe they are a better match for aluminum heads and blocks but studs are meant to stay in one place in the block so don't oil them.
Old Oct 23, 2014 | 10:52 PM
dusty1's Avatar
I used the old bolts and had one misfit. used a tap on that one...because I had one on hand, in that size.
Old Oct 24, 2014 | 05:58 AM
drowssap's Avatar
you should use a thread chaser or a 7/16 x 14 bottoming tap
Old Oct 24, 2014 | 09:33 AM
04duxlr's Avatar
I would say ideally you should use a thread chaser, especially for tty bolts as their installation requires an initial torque followed by rotation within the threads and both of these actions are impacted by crap within the threads. However, for studs you will be installing them in the holes initially then the torque is purely a function of the nuts rotating on the threads on the studs so it isn't as critical.
The machinist that did my cylinder heads told me that a tap should never be used as it can cut a little more material which is the last thing you want for these blocks. A thread chaser is slightly smaller in diameter than a tap and has a different angle on the leading edge to make sure that it doesn't remove any of the threads, only restores them. For my block, the holes were mostly spotless so I didn't take it any further but had I needed to, I was going to grind two relief slots up the sides of one of the used head bolts to act as a chaser. On one of the holes, I had to use a dental pick I had to scrape out a little bit of stuff but that was it.
Old Oct 24, 2014 | 05:43 PM
coors's Avatar
I am going studs.
For 30+ bucks I'm skipping the thread chaser I'll just have to make sure the thread holes are completely clean,clear, and dry. I'll make it work. Thanks guys.
Old Oct 24, 2014 | 10:12 PM
acamato's Avatar
When I did my heads, I was gojng to get a bottoming tap to chase the threads. Then I read that you shouldn't because the tap will cut some material off the threads and loosen the fit. I ended up getting loaner thread chaser kit from Autozone.
CANAMDiscovery
Apr 22, 2013 08:34 AM
Willie00d2
Feb 25, 2013 02:56 PM
Rearden Steel
May 7, 2012 08:23 PM
DrippyDisco
Jun 6, 2011 11:57 AM
vwtech
Mar 6, 2011 03:04 PM
