ATF at the bellhousing???
on
1 Post
Guys, just dove under the truck to verify why in hell I still have an exhaust leak, and sure enough I found that I broke a stud again.
Anyways,my reason for writting now, is that I found what I think is ATF at the bellhousing, where oil usually gather. Is it possible that oil would leak out of the transmission at the front, inside where the tranny meets the engine and leak down to end up at the bellhousing???
I still have to confirm if it is ATF, but it sure has the same consistance and its red. I know coolant is red, but its thicker than that.
on
1 Post
MMMMM, wonder if it could just be left over oil from my ATF oil change last week-end ?!?! I remember check it when cold, and it came flying out for a second. Sure hope I'm right, cause the lines are fine, and the pan is well sealed all around with no evidence of leakage.
