ATF leak 97 Disco
Old Nov 25, 2005 | 02:30 PM
adowgiert's Avatar
Default ATF leak 97 Disco
I've got a pretty bad tranny fluid leak coming from the tranny oil cooler. It leaves a puddle by the front passenger tire every day. Does anyone know if this is a common problem and, if so, what is the usual cause? Any help would be appreciated.
Old Nov 26, 2005 | 12:03 PM
Hank's Avatar
Default RE: ATF leak 97 Disco
Sure it's ATF??? There are no ATF lines to leak anywhere near the Pass side wheel....
If it is coming from the Trans oil cooler, seems it would have to come from the fitting on the pass side, or the cooler has a small hole in it. Just pull the grill off and have a look. You may just need to tighten the fitting. If the cooler is damaged, I have one you can have for 20.00 plus shipping...
Old Nov 26, 2005 | 01:07 PM
adowgiert's Avatar
Default Tranny leak fixed
The leak got really bad yesterday afternoon so I rushed it to a local mechanic and, $175 later it's all fixed. It was the oil cooler, they put in a $60 aftermarket aluminum cooler and all is well.....quite a load off considering we're 500 miles from home right now. Thanks for the advice!
bonus999
Jan 3, 2017 10:19 AM
Skids69
Oct 29, 2013 07:44 PM
bantham1
Oct 2, 2010 10:05 PM
tgwaldop
May 14, 2009 01:28 PM
unstable
May 6, 2008 09:36 PM
